injectors installed
Old Nov 11, 2009 | 11:31 AM
Diesel Demon's Avatar
injectors installed
Got my 120 hp injectors in yesturday. What a difference like driving a different truck. With the edge set at stock setting i can really tell the difference. turning it up all hell breaks lose. Thats what i call fun. It smokes more but living in the middle of nowhere dosent bother me. There is lots of diesel smoke anyway from all the farmers around here. Going to strap it to a dyno soon. will post numbers then. Took the old injectors apart to check them out they were toast.
Old Nov 11, 2009 | 11:58 AM
blue_bandit's Avatar
what brand of injectors did you get, and where from?
Old Nov 11, 2009 | 02:23 PM
RowJ's Avatar
Originally Posted by Diesel Demon
....Took the old injectors apart to check them out they were toast.
Define "toast"?
How many miles on them?
RJ
Old Nov 12, 2009 | 12:22 PM
There were 335.000 kms on the injectors. We pop tested all the old injectors and they were down the pop test to 2800 psi. the ends of the needle on the injectors were in bad shape. They did not have a good spray pattern on them. I got the injectors from Prince Albert diesel injection. they are a Bosch injector.
Old Nov 12, 2009 | 12:50 PM
RowJ's Avatar
Wow!
That's a lot of KM's. Have heard of some factory injectors being weak at 1/2 that... or basically 100,000 miles (170,000 km).
Combination of new AND bigger must really make a nice difference!
RJ
Old Nov 12, 2009 | 12:52 PM
scottsjeeprolet's Avatar
what are your EGT's at? Still have the stock turbo? HY or HX35
Old Nov 12, 2009 | 04:55 PM
Still the stock turbo on the truck. I will change the turbo when I get a set of head studs. The egt temps have been running fine. I was playing with it on wedsnday out on the highway. with egde set on 5 the highest temps i could get were 930 degrees.
Old Nov 12, 2009 | 06:27 PM
Those numbers gotta be post turbo. No way that's correct.
Just stock injectors on 5 you should easily hit 1200*.
Old Nov 12, 2009 | 07:05 PM
lovinCTD59's Avatar
Good point here. If you have 120 HP sticks and an Edge you will be gettin Pretty Hot, especially with a stock turbo!
Old Nov 12, 2009 | 08:01 PM
lvmknsmoke..'s Avatar
yup exactly, i have a tst with ez and i can easy hit 1200.
Old Nov 12, 2009 | 08:21 PM
blackcloud 98.5's Avatar
lol i agree i have stock inj. and turbo and all i have is an edge ez and i can hit 1200
Old Nov 13, 2009 | 08:29 AM
I will double check the numbers this weekend. When I hit 930 I did not hold it very long on the floor. I have hit 1100 will towing but i was towing in overdrive. My brother in law want to race my truck with his duramax this weekend. I will watch the egt temps to see what kind of numbers I get and let you know.
Old Nov 13, 2009 | 08:45 AM
wurkenman's Avatar
Gotta agree with the guys here. With the setup in my sig, I can easily hit 1650+ on a WOT pull. Better check it before you have to pick up pieces.
Old Nov 13, 2009 | 09:01 AM
RowJ's Avatar
I will double check the numbers this weekend ...... I have hit 1100 will towing but i was towing in overdrive.
As mentioned above.... Is your EGT probe before or after the Turbo?
RJ
Old Nov 13, 2009 | 09:41 AM
It is after the turbo on the elbow
