Injectors Installed
Old Nov 18, 2002 | 10:51 AM
jec3's Avatar
Injectors Installed
Had some decent weather so installed my 275 injectors over the weekend. <br><br>Suprises: With only 64K miles on the truck I was surprised to see how dirty the old injectors were. Lots of carbon built up on the injector tip and nozzle holes. It didn't appear any were plugged but have to wonder how they would look after another 64K.<br><br>Recommendations fr anyone planning on doing this job for the first time: Cut a 3/8 inch slot out of a 19mm or 3/4 inch box end wrench. This will help immensly in extracting the #6 injector line at the head - very little room to work under the cowel at the rear of the engine.<br><br>Also, after replacing the first four injectors, I reinstalled the plenum which has the oil dip stick bolted to it. Working on 5 &amp; 6 I was leaning/laying on the front of the engine and plenum. Well I ended up braking the handle off of the oil dip stick. So your tip is remove the dip stick first!<br><br>Job took about 3 hours and truck seems to run much stronger. ;D <br><br>
Old Nov 18, 2002 | 11:23 AM
jec3's Avatar
Re:Injectors Installed
&quot;Of course, the secret was a twenty-foot multi-ladder set in a scaffolding position -- two ends on either side of the fenders, and the central scaffold across the open engine compartment -- me lying across it and simply reaching down.&quot;<br><br> <br><br>I tried without removing the plenum but found it to be a hassle so just removed the 4 bolts and moved it aside about 4 inches. A couple of my injector lines were so tight I had to use a breaker bar with the crows foot to break them loose. That #6 was one of them. After I ground the 3/8 notch out of the box end wrench so I could get it over the line, I was able to back the bolt out with short strokes which probably saved me about 10 minutes of frustration.<br><br>Of course now that I have done this job once, next time will be much easier but I did tell myself as I was sprawled accross the engine bay &quot;why am I doing this, the truck runs great already&quot;. Now that it's all done I am all smiles... <br>
Old Nov 18, 2002 | 11:38 AM
97CTD's Avatar
[quote author=jec3 link=board=7;threadid=7188;start=0#68694 date=1037640218]<br>tell myself as I was sprawled accross the engine bay &quot;why am I doing this, the truck runs great already&quot;. Now that it's all done I am all smiles... <br><br>[/quote]<br><br><br><br>I like to go by the old saying &quot;if it aint broke fix it till it IS!!
Old Nov 18, 2002 | 02:36 PM
TPilaske's Avatar
It was rough watching my injectors get put in last thursday! <br><br>Tony
KRB
May 20, 2007 06:20 PM
rjm022
Nov 23, 2006 11:29 AM
BIGOKIE
Jul 21, 2004 05:53 PM
Farmout
Jun 30, 2003 11:34 PM
