injectors and hx35
Old Mar 7, 2010 | 03:19 PM
piles's Avatar
injectors and hx35
im currently running a set of rv275's and was considering bumping them up to a set of F1 150hp injectors instead of buyin a Quad ADR, questions is....am i gonna smoke like a freight train and have egt issues or will it be fairly controllable with my hx35. I figured i would be fine but the guys at NADP tell me im gonna be rollin coal uncontollably with 150hp sticks!??
Old Mar 7, 2010 | 10:29 PM
Clunk's Avatar
Probably gonna get a little warm with the injectors but a boost elbow that'll let you raise your boost to 33-35 psi will help.
Low rpm smoke will be pretty bad at WOT/control it with yer foot and rear view mirrors.
Old Mar 8, 2010 | 07:59 AM
RowJ's Avatar
Originally Posted by piles
.... but the guys at NADP tell me im gonna be rollin coal uncontollably with 150hp sticks!??
With some yes.... but the F-1, Mach 4's are not like that. They smoke less than any 150hp injectors on the market.
You do have to be careful accelerating w/o downshifting. And you can blacken out an intersection any time you want to.
But they are fairly easy to control with a bit of re-education.
By that I mean you need to start shifting a bit later than you probably do now.
And that's a good think, IMO. Most guys shift to soon anyway.
Mach 4's are excellent injectors and I would not be afraid to run them.
Your HX-35 will handle them ok. Boost elbow and Boost fooler will help...as mentioned.
Your only EGT issues will be at sustained WOT.... or heavy towing.
RJ
Old Mar 8, 2010 | 11:19 AM
rebal's Avatar
My mach 1.6 will push my hx 35 past its limit I can hi 42PSI on a long grade towing I think mach 4 would work as a play truck but you would need to keep an eye on EGTs
Old Mar 8, 2010 | 09:26 PM
piles's Avatar
thanks for the good info guys, i really appreciate it, i think i'll go ahead an get the Mach 4's when i order my pump,hopefully before end of this month. god knows money is tight these days so i wanna make sure im not left "wanting more" this time an havin to buy twice.
Old Mar 9, 2010 | 07:55 AM
Joe Diesel's Avatar
ill be in the same boat soon but before i uprade to a HTT turbo & my M4s ill have to do some head work either head studs or firering ...
Old Mar 9, 2010 | 04:02 PM
jdwest's Avatar
I don't know if this will help but...A few years back I owned a 2000 2500 2wd reg cab 5sp. I was running Mach 2.5's and a Catcher with 4" straight pipe, lift pump relocation, and an AFE intake with the stock HX35. That sucker ran HOT! About 38psi of hot boost and 1300 deg pre-turbo running it empty. Playing with it you could see 1400 deg pretty fast. Man that was a fun truck! Pretty darn quick for what it was...
Old Mar 9, 2010 | 04:19 PM
Tate's Avatar
For 99% of the time, your smoke and EGT's will be completely controllable. WOT will obviously produce smoke and heat, but thats the case regardless of what setup you have. I ran 140hp injectors in my 12v with the HX35 and it was a real fun truck, real responsive.
Old Mar 9, 2010 | 08:46 PM
DRD's Avatar
DRD
Your experience may vary but if you tow heavy the HX35 won't cut it. Even with my baby RV275's I have to watch it and get out of the pedal going over the mountains in the summer. I Have the power to pull harder just the EGT's get out of hand.
big stinky
Apr 8, 2008 09:01 AM
KRB
May 20, 2007 06:20 PM
TexasHardcore
Aug 13, 2004 10:53 AM
ClawHammer
Aug 7, 2004 08:49 AM
BIGOKIE
Jul 21, 2004 05:53 PM
