Which injectors?
Old Nov 12, 2005 | 04:33 PM
Flatty's Avatar
Which injectors?
Now people keep talking about eh Mach1.6's, but at 700 for a set, that is rather pricey... I know,, you get what you pay for, however, I had to put a new tranny, injection pump, batteries, starter, and some other small odds and ends this week... Now I am putting a catcher with some injectors, but want to know which ones are good price wise as well. Are the bosch any better than stock? I can get those for about 400 a set.
thanks
Dima
Old Nov 12, 2005 | 05:21 PM
caleb c.'s Avatar
If I couldnt get the F1 injectors I would probally go with the Jammers.You can get jammer nozzles on stock bodies at www.citydiesel.net for a good price.
Old Nov 12, 2005 | 06:39 PM
J BODY's Avatar
all depends on how strong that "new" tranny you had installed is.
Old Nov 13, 2005 | 11:56 AM
Flatty's Avatar
Strong enough to handle oveer 500 horses. tripple lock converter,all heavy duty stuff in there.
Dima
Old Nov 13, 2005 | 12:03 PM
Flatty's Avatar
http://www.citydiesel.net/jammer-inj...lete-p-47.html
Will these 100hp injectors require turbo enhancements? How will those work with the catcher ECM?
Thanks
Dima
Old Nov 13, 2005 | 12:07 PM
sleds's Avatar
If you have the money mach's are probably the best. IF you don't, buying the jammer tips from a reputable source and having an injection shop assemble them and check the pop-off pressure is a good way to go for less $.
Old Nov 13, 2005 | 10:40 PM
newriverSpecon's Avatar
Thanks
Dima
To effectivly use them, yes there will need to be turbo changes. Right now I'mm running the 125 Jammers and on level ground have no issues. If I load it I have to watch the EGT's. I get 23-25 psi with stock waste gate and no fooler.
After some help from the local ECM expert (thanks MARCO) I am going to check the dealer for cost of updating my ECU. Depending on that I may end up going for a MAD.
Randy
Bradleysram
19
May 12, 2009 08:36 AM
KRB
May 20, 2007 06:20 PM
BIGOKIE
Jul 21, 2004 05:53 PM
mcevins
Dec 2, 2003 11:38 AM
atc250r
May 12, 2003 02:56 PM
