Injectors
Old Nov 5, 2008 | 09:49 AM
arcticcat12224's Avatar
Injectors
Thinking of getting a Set of 370 Marine injectors for my truck.
They were built by Piers Diesel and we just tested for cracks and they flow good.
What are the positives and Negitives for these injectors what is a good setup for them.
I still have the stock turbo on my truck am i going to need something larger?
Any input would be helpful,
Thanks
Old Nov 5, 2008 | 10:07 AM
PaulDaisy's Avatar
I have read that Marines don't have the optimal spray pattern for the truck engines, whose RPM vary a lot.
Old Nov 5, 2008 | 11:33 AM
I have also read that and herd bad thing like I stated above.
I dont know if the spray pattern would be different from the ones made from Piers.
Old Nov 5, 2008 | 04:52 PM
97 D-Tec's Avatar
dont even put those in unless u have gauges.. more fuel means more heat if u cant monitor the heat u risk the chance of hurting something.
Old Nov 5, 2008 | 07:40 PM
Ha already past that bud,
Full gauges fuel pressure,EGT,Boost
I got 50hp injectors in now 550H\P SouthBend
SB intake, 5 in exhaust so she can fart
Old Nov 5, 2008 | 09:29 PM
OutlawStorm's Avatar
Marine 370s are not the best injector,, they tend to haze at idle, and like stated are not the correct spray pattern,,, i would sujjest spending a lil more and getting something with the correct spray,, my DDPs are great,, but prob not enough power for you, they make them with more HP to, but cost more,
To me I would spend more and get a good injector.
I would have went bigger but Ross didnt recommend anything more than the stage2's I bought cause I tow heavy alot
Old Nov 6, 2008 | 04:36 AM
97 D-Tec's Avatar
pure diesel power has their own inhouse 140hp injectors they are selling for like 500 .. im going to call em n see if they are any good
Old Nov 6, 2008 | 10:31 AM
Fueling around's Avatar
Advantages of 370 injector?
Inexpensive and reliable injector. Good power upgrade. With a larger bowl piston they run very nice.
Disadvantages?
Others already posted as haze (both idle and even lower rpm) and spray pattern. If you keep the timing advance down the spray pattern is OK (not great, just OK). I think they are excessively smoky with stock pistons.
Which year truck (engine & pump) do you run? The 94 & 95 pumps usually need delivery valves to work well with any larger injector than a 215.
Old Nov 6, 2008 | 01:11 PM
Well right now its a 94 with the stock dilievery valves.
Who sells a good set of 191 Ive herd good comments of thoes.
Head studs will be coming soon. 97 D-tec you said something about 140h\p injectors, who makes thoes keep me posed im interested on them!
Im in the process of aquiring a Holeset HE431VTI If anyone can tell me something about this turbo it would be great.
Old Nov 6, 2008 | 01:51 PM
Better way is to find someone that has a 96-98 manual transmission ans is upgrading their DV to insanity levels. They are 181's which are really nice and support a lot of fuel/injector. Free as you take the 181s and give them your 161s to return as cores
HE431VT is a variable geometry turbine housing found on the ISL-07 engines. Nice converstion piece for your desk. I don't know of anyone that has come up with the electronics to control one.
Old Nov 6, 2008 | 03:21 PM
Could you tell me more about the electronics on it what do they control and stuff like that.
Is it similar to an HX-40?
KRB
May 20, 2007 06:20 PM
GSP
Dec 11, 2005 12:20 PM
W.F.O.
Nov 3, 2005 10:33 AM
darrenG
Jun 21, 2005 10:24 PM
BIGOKIE
Jul 21, 2004 05:53 PM
