Industrial Injection Dragon Fly 12V Pump
he works at DI in cinnci call and ask for james, tell him patrick sent you and what your looking for.
he does not recam them on a tune up. he can get about 580-600cc's on stock components, he can also build quick cam 13mm pumps, custom turbochargers/exhaust housings, ect...
most performance work is done on the side (besides pump work) so youll just have to call about time frame.
I get my pump work done by James Grubbs
he does work for Hailsey (he built curts turbos) and If im not mistaked be did Bobcats pump as well. among many others
He is top notch. He uses a stand with electronic fuel metering. He spends alot of time tuning each p&b to flow as closely to the others as possible which is what results in a smooth pump.
My pump is extremely smooth, starts without any throttle, and achieves 19mpg at 621hp with 30* timing and my truck has 4:10 gears
Dam your the man.
I could only muster about 21 out of my street truck, then I had problems with cold start up and knock when towing.
I have ran lots of II parts, pumps, turbos, Injectors, Brady has always helped me pick what parts I should be running (for my intended use and buget). And always had the parts at my door a day earlyer than what he said they would be.
I have had the Dragon Flow injectors in several of my trucks. And loved them.
And his prices seam to be in check or cheeper than most of my local venders.
JMO.
Ron R.
lets talk numbers. what are the dragon flys producing?
I can have a 160 pump making 580-620cc's at 1000 strokes for about $500
a stock pump will make about 190cc's
my tuned 215 only made 460cc's and my truck makes 621hp and it wasn't clearing the fuel. 580cc's should easily produce 800hp
so for $500 you could have a 800+ hp capable pump tuned, and timed
or $1600 for a 750hp capable pump.
just trying to save people some money from buying somthing they dont need
something to consider.... Ill keep it in mind
Rick
93-12Smoke
Aug 29, 2013 02:02 PM
dieselfumes57
Nov 6, 2008 05:34 AM
MikeyB
18
Oct 24, 2008 06:54 PM
masonic-dodge
22
Jul 27, 2006 05:40 AM
sleds
Jan 13, 2005 06:23 AM
