Individual runner intake manifolds.
Old Feb 26, 2010 | 12:36 PM
justme-'s Avatar
justme, First off, just try and port the intake side of the plenum. You'll see why you cut off the plenum. Both #1 and #6 are very restrictive. Secondly, put you fingers in there and pretend that your a molecule of air trying to get into those cylinders. Now try to cram in lots of air.
Got it- there is enough improvement being able to port/polish and open up the runners with this method for significant gains. I wonder then, if following theory, a header style manifold would have enough gain over a box plenum to be worth it.
Old Mar 2, 2010 | 08:54 PM
Mike Holmen's Avatar
The Guru
Depends on you goals. If you building a drag racer/sled puller yup its will help. It you just daily drive the truck, its not necessary. You planning on using an aftermarket cam? How much you planning on reving-up the engine? If you want the engine to breathe over 4000 rpm's, you need to improve the air flow into the cylinders in what ever way you can. If you will driving you truck under 3000 rpm's, just do a pocket port and some port clean/smoothing. Swamp is building one heck of killer motor for his ride.I can't wait to see how it pans out on the dyno and at the track.
Tmello401
Dec 20, 2012 01:02 AM
D45
17
Dec 6, 2007 01:52 PM
Bobcat698
33
Sep 25, 2005 09:31 PM
RowJ
Jul 20, 2004 10:36 AM
Buzz
Nov 20, 2003 05:52 AM
