important blue pump queustion
Old Jun 1, 2006 | 06:37 AM
edy's Avatar
edy
i have a question i ordered a blue pump they it has a pressure pre set at 14 psi can you raise it and how do you adjust the spring in the pump everybody is always talking about streching the spring wear is the spring located.
Old Jun 1, 2006 | 09:42 AM
bluedodge3500's Avatar
on the side of the pump towards bottom is a screw you can stretch the spring or moroso sells a new spring kit to up it
Old Jun 1, 2006 | 11:45 AM
BigBlue's Avatar
Don't play with it. I'm running just the factory spring in mine and have 15 at idle and 11 at WOT with 400hp. Upping the pressure is only going to put undue stress on the pump and your not going to gain anything from it.
Old Jun 1, 2006 | 07:20 PM
edy's Avatar
edy
thank you for the info but if i wanted just a little more fuel pressure can i strech it a tid bit
Old Jun 1, 2006 | 07:36 PM
BigBlue's Avatar
Better thing to do is to put a small washer behind the spring to shim it instead. Just remember that your not gonna gain anything but a higher number.
Old Jun 1, 2006 | 07:54 PM
edy's Avatar
edy
i know but i wnat it to idle between15 to18 psi
Old Jun 1, 2006 | 10:41 PM
BigBlue's Avatar
Mine idles at 15 and has been for two years. Idle pressure is not what you need to worry about. It's cruising and WOT that you need to worry about. The VP44 can idle with almost zero pressure forever.
Old Jun 2, 2006 | 07:20 AM
edy's Avatar
edy
i know wot is more important i have a big fuel line kit but if it idles at 17 to 18 psi at wot it will probally drop to about 14 or 15
Old Jun 2, 2006 | 03:55 PM
STACKED's Avatar
I've got the blue with regulator turned up, no stretched spring just right out of he box pushing 21 idle and 16 WOT
RoadDiesel
Dec 29, 2014 09:11 AM
hellotbone
Dec 9, 2003 12:32 PM
admin
17
May 3, 2003 11:45 PM
Hummin Cummins
Feb 20, 2003 07:32 AM
