If two weren't enough.....
I was doing some research the other day and came across some information that I thought was interesting and figured I would tap into the volume of experience that is this forum.... I read where the TS MVP has great lower end power and does not tap the pump wire.... I see where guys are putting the TS MVP on for the bottom end and the TST Powermax3 Comp for the top end and using the smarty to smooth out the power curve (even saw an old dyno run where it did show the curve smoothed out after the Smarty was added.....
Not sure what the street manners of that would be though, and all of the info that I am finding is older, and not much in the last few years. So I was wondering about recent info and if the programs on these units has any smoother manners and is not like dropping a hammer making it all or nothing power. I guess the MVP comes on like the TST about 8-11#'s of boost while the Smarty comes on down low, but is smooth and steady yet falls on its face up high..... I do like the MVP as it has good power without tapping the pump wire, although the TST has to have the wire tapped and obviously the Smarty is flashed on the ECM.....
Dodgezilla
47
Feb 22, 2008 10:02 AM
Dave88LX
Jan 8, 2007 10:41 AM
