I hate to ask this question, BUT
Old Oct 6, 2006 | 01:13 PM
1qckdodge's Avatar
With my new combo should I see 400 to the wheels? II 62/12, TST COMP, re-flashed Catcher with #9 from Smarty(dont ask) Edge stage 5s, AFE MegaCanon, twin lift pumps, I think thats everything, Thanks
Old Oct 6, 2006 | 01:20 PM
getblown5.9's Avatar
yes...in short you will see over 400hp
Old Oct 6, 2006 | 02:53 PM
Ph4tty's Avatar
No doubt you'll see more than 400
You have less turbo, but more fuel than charlie8301 and he did 470+
Old Oct 6, 2006 | 03:49 PM
Charlie8301's Avatar
not sure what those injectors are rated at but I assume there bigger then my 1.5's, so you should be at least at the 470hp mark.
Old Oct 6, 2006 | 04:50 PM
1qckdodge's Avatar
Thanks guys, the turbo is gonna be going back to II for an upgrade, I dont know how hot my egts will get because my box just came back from TST for a quick repair, as a matter of fact UPS is pulling up right now, without the TST the truck still feels great, it spools pretty quick and hits 40 psi and stays there, Im gonna hate to put the HX back on when I send it out, my only problem is I dont know how big I should go, I was thinkn maybe a 64/14, any thoughts?
Old Oct 6, 2006 | 05:06 PM
I would go with the PS64, seems to be a good "middle of the road" turbo, spools well but still seems to cool. I ran a 66 for about a week, spool up was very slow and it had a bad surging problem, It would make a good drag turbo but has very bad street manners. Didn't get to run a silver bullet but if you plan on adding more fuel it might not be a bad idea.
Old Oct 6, 2006 | 05:40 PM
1qckdodge's Avatar
Wow, thats all I can say, I just came back from a quick test of the box, this thing rocks, its about 45 deg here so traction is a big problem even in 2nd gear, this was the first time I turned the box up to level 5 (I know it has 9 levels im nervous about breaking stuff) the turbo really made the top end come to life, it just kept pulling till I girlied out and lifted, I dont even have a shuttering problem like people have talked about, im running 30 psi at idle and since that and the addition of the smarty program the shuddering has all but stopped, oh well im going back out to waste fuel Charlie those are some awesome #`s, hows it pull?
Old Oct 6, 2006 | 06:04 PM
jhood12's Avatar
I dont think you will really have the shuddering problem till you put it in 9 and really get into and then let off.....atleast thats the way it is with mine..
Old Oct 6, 2006 | 06:25 PM
BCB's Avatar
BCB
is this right??? or are you talking about fuel PSI
Old Oct 6, 2006 | 06:31 PM
1qckdodge's Avatar
Im sorry, thats 30 psi of fuel pressure @ idle 30 lbs of boost at idle might be a big problem
Old Oct 6, 2006 | 07:50 PM
BCB's Avatar
BCB
sure would make for one quick truck too!
Old Oct 6, 2006 | 07:56 PM
Tow or Pull. I hardly ever tow with my truck, the only thing it ever gets hooked to is the sled. I had a 91% converter with very low stall and i had a hard time getting on top of the turbo before the 100ft mark. Switched it late in the season to a 89% with a higher stall but only got to pull once on the new converter. There's a video in my sig
Randy
05CTDN8
Jan 23, 2007 09:35 PM
ptgarcia
27
Nov 18, 2006 09:00 PM
PanteraGSTK
Oct 25, 2006 02:24 PM
triton0708
Apr 21, 2006 04:22 PM
ppsi
May 31, 2004 12:50 PM
