I curious on this combo...
Old Jun 14, 2006 | 12:18 AM
one54ton's Avatar
I plan on this combo eventually:
AFE satge 1
4 inch exhaust
Bell USB 62mm turbo
HRVP44
Mach 6s
Drag Comp
Studs
What kind of power am I lookin at?
Old Jun 14, 2006 | 12:35 AM
BigBlue's Avatar
That turbo is going to be to small for those injectors. Your going to need at minimum a 66 to support that kind of fuel. Twins would be your best bet for those injectors. Other than that your probably staring 600-650hp in the eye.
Old Jun 14, 2006 | 12:45 AM
Ph4tty's Avatar
I don't know jack about the bell usb turbos, but assumming its comperable to a phatshaft or htb2 I'd guess 550. I'm thinking you're short on air with that much fuel. Sps66 should take that combo to 600.
Stealing from some of Don M's posts:
Originally Posted by Don M
Where the HRVP44 only needs a M4 size stick to make 600 with a wire tap box or close to 500 without, the standard SO pump needs a M6 or larger.
Yeah we had a guy with 4's, an Edge COMP and a big single ( i think a PS66 ) make 604 using the HRVP44!!!
Old Jun 14, 2006 | 12:47 AM
Ph4tty's Avatar
You beat me to it cuz I was searching through Don's posts for injector recommendations
Old Jun 14, 2006 | 01:39 AM
getblown5.9's Avatar
AFE satge 1
4 inch exhaust
Bell USB 62mm turbo
HRVP44
Mach 6s
Drag Comp
Studs
guy at the track one night had this same set-up but with smaller mach 4's...this truck was an ext cab short bed, 6" lift, on 37" tires running 13.6's
id say its right around 500/1000
Old Jun 14, 2006 | 08:03 AM
Jetpilot's Avatar
You need a larger turbo for this combination.... Something in the 66mm size will be warranted. Also You don't need both the HRVP and Mach 6's. Test are showing that Mach 4 - Mach 5 are showing max HP with a HRVP. So you can save some cash by going with a HRVP and Mach 4's or a OEM pump and using Mach 6's.
If we can answer any more questions please feel free to call.
Doug Smith
Old Jun 14, 2006 | 05:50 PM
one54ton's Avatar
Are mach 6s and an HRVP44 to much fuel?
Old Jun 14, 2006 | 09:29 PM
BigBlue's Avatar
No. It's just that the HR maxes out sooner with smaller injectors because it puts out more fuel and doesn't need a super large injector to make the same power. Both pumps max out at about 650hp or so.
INsIdious
Apr 6, 2004 12:41 PM
Hoss
Mar 6, 2004 06:33 AM
Sittenbull2
24
Oct 20, 2003 01:02 PM
Ben
Sep 19, 2003 02:18 PM
