Hybred turbo??
Old Mar 17, 2004 | 10:24 PM
Haulin_in_Dixie's Avatar
Hybred turbo??
Can someone tell me exactly what parts go into a hybred 35/40. Also is the exhaust turbine and shaft the same in the HX35 and HX40? The bearings are the same. I am thinking that the hybred is the intake compressor wheel and housing of the 40 mounted on the 35. Is that right?
Old Mar 18, 2004 | 01:50 AM
PourinDiesel's Avatar
Thats right.
Old Mar 18, 2004 | 12:47 PM
Borush's Avatar
I'm gonna be going to a hybrid soon.
There are several different hybrids available. The PDR uses a 58 mm compressor wheel, HT Turbo has a 60mm wheel, and Dodgezilla has a 61 mm wheel. PDR has a version that will work with the stock 24V 12 cm exhaust housing. The others use the 12V style housings that have the wastegate actuator mounted to the turbine side and require a new exhaust housing on 24V engines, but most people go with a bigger exhaust side anyway for better exhaust flow.
Boyd.
Old Mar 18, 2004 | 04:30 PM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
I love my 60mm from HT Turbo they did a knockout job had good customer service. Even though i didnt get my deposit back, my WH1C got bounced in the mail screwed it up pretty bad, it was not worth arguing about, they were very appologetic and did off set the price some to try and make it right. But that 60mm really made a huge difference, any they were right there helping me tune the watsegate and figuring out my fueling needs to best match the setup.
Old Mar 18, 2004 | 05:20 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
I got my hybrid from the good folks at Wildcat Diesel, It came in a box marked Dodgezilla
Do I like it you ask?..........
Wouldn't be caught with out it now And I don't have to say anything about Wildcats terrific service....well OK you forced it out of me
As every encounter I have had with Wildcat Diesel, I ended up with a smile on my face
Great Guys!, Great products, Great people!.
You have my permission to quote me
Old Mar 23, 2004 | 02:41 AM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
To add to your confusion, there is a version of the Dodgzilla currently in testing/release mode with a 7 vein 63mm wheel. We've got a couple brave customers running them right now, and they're very happy with the charger. We're seeing slightly better spoolup than we did with the 61mm, and at 350 HP levels, about 50F less EGT than with the 61mm wheel.
Rod
Old Mar 23, 2004 | 04:12 AM
Rod
Rod what I have is a hx40 with a bad exhaust turbine. The compressor and housing is perfect. Trying to figure out where to go with it. Right now not doing anything with a cracked block, but after will play with it. You did hear that the new engine is now cracked..
Old Mar 23, 2004 | 11:48 AM
MCummings's Avatar
Ohhh, Man !
Have you put up a thread about it yet? That sucks.
I would nominate you for the "worst luck" award on DTR.
Merrick
Old Mar 23, 2004 | 12:40 PM
A week or so ago, "Is all this possible, or am I dreaming" was the thread. Hey, not so bad, it only leaks on one side
Old Mar 23, 2004 | 01:13 PM
ddestruel's Avatar
a gallon of coolant every 100 miles thats not too bad. Feel for ya
Old Mar 23, 2004 | 01:32 PM
MCummings's Avatar
When I blew my motor, I was using 2 gallons of oil every 150 miles.
I had to drive 500 miles. I don't think the underside of my truck will EVER rust..lol Nor, Will I ever find a mechanic who would want to do any work underneath my truck.
We can now return this topic back to it's original subject..... heheh
Merrick
Old Mar 24, 2004 | 12:34 AM
Eat Beef's Avatar
From: Alberta Foothills - Power to grow with 6 in a row - XLR8
R
od
Rod,
I need one of those!
Andy
Old Mar 24, 2004 | 01:49 AM
BigBlue's Avatar
What about putting a stock HX35 on my truck? Would it be worth it? I'm thinking bout doing this just to give myself a little extra on the top end.
Old Mar 24, 2004 | 04:39 PM
An HX35 will give you more top end HP and should drop your high RPM EGT's a little. It will also give you the option of changing to even less restrictive turbine housings in the future if you get bigger injectors. If you can find one for a good price, go for it.
Old Mar 24, 2004 | 06:13 PM
BigBlue's Avatar
Sounds good. I'm getting about 1200* pre turbo right now. I'm hoping the Scotty 2 will drop that a little bit and then maybe the HX will drop it a little more.
Ada381
Feb 10, 2008 07:58 AM
1320
May 22, 2007 10:47 AM
1320
May 9, 2005 12:32 PM
drawson
Jun 27, 2003 01:13 AM
redram
Dec 10, 2002 09:54 AM
