hy35 enough or do I upgrade?
My 01 has the hy35 like most autos that year. Ive got the wastgate turnbuckled of j hooked however u look at it and I'm running 25 pounds of boost. I've got my box, bigger sticks, fuel kit and tranny built. The last thing im thinking about doing is a turbo upgrade. Do i stick with the one i have or is it worth getting like a hx35? I like the faster spooling of the hy but the lower egts would be nice. Its a daily driver. I don't pull very often. It's my around town ego enhancer. What should I do? thanks in advance
With all the smoke she pours out I think I know where all the fuel is going
I got a good offer on a pdr35. Its a 12cm 58mm I'm told. I found some info saying above 400 hp it would be overmatched. Is that true or would it work ok. I don't know how much hp i'm pushing but I was thinking more along the lines of 450hp. I don't want to spend $1500 if I can help It. I would like the pdr35 if it can handle it.
The H-Charger 60/12cm non wastegated from HTT looks like something that would spool almost as good as the hy35 yet is rated 315-415hp. I heard the sps62 has lag compared to the hy35 but will cool great later in rpm range. I also do not want to forfiet the hy spool up. My goal is 350rwhp. Does anyone have experience with the htt 60/12, thanks
The H-Charger is just HTT's name for a hybrid HX35/40. I got the HTT compressor upgrade to make mine a 60/18, and I can still get the EGT's to around 1300. I wouldn't recommend a non-wastegated 12cm.
A hybrid won't be enough for Dodgin&Rammin either with his mods.
If you are really making 450HP, pony up for a Phat Shaft 62/14, or at least a BD Super B. A 35 series is just not going to be happy with that much fuel. You'll be going with a Custom turbo sooner or later at that power.
