HX35, HT3B twins questions
Old Aug 19, 2005 | 07:45 PM
Clucker's Avatar
I know a lot of guys have done the HX35/HT3B twins setup
My question is for those of you who are not running the externial WG what did you do to the WG/exhaust housing on the HX35
Did you run an adjustable fooler elbow on the 35WG?
Thanks for any tips
Old Aug 20, 2005 | 11:17 AM
1ST GEN.'s Avatar
I kept the stock boost elbow and kept the wastegate at 20psi, but I drilled a hole through the center turbine housing divider so all 6 cylenders would be wastegated, and you can enlarge the wastegate holes to just under the size if the flapper
Old Aug 20, 2005 | 03:09 PM
Clucker's Avatar
thats what I was thinking but I wanted to check
did you install popoff valves also?
whats your max boost
are you using the 12CM hx35 and the 26cm ht3b?
Old Aug 20, 2005 | 10:43 PM
1ST GEN.'s Avatar
I do have pop off valves, i'm not sure what max boost is I don't have head studs, but It will race past 55psi with ease
Old Aug 21, 2005 | 12:02 AM
cumminsdriver635's Avatar
How does this combo spool compared to stock, and will it lower EGT's a bunch. Just curious for the future.
Eric
Old Aug 21, 2005 | 09:27 AM
1ST GEN.'s Avatar
It spools slower than stock but they still spool quick, they do lower max EGTs but while cruising the EGTS are about 200 degrees higher
Old Aug 21, 2005 | 11:00 AM
RonA's Avatar
The sets I have seen run around 600 to 650 at 65mph at 100 to 800 ft alt. Mine run there also.
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
blackdiesel
29
Jan 5, 2006 02:46 AM
1320
Sep 12, 2004 11:23 AM
SjLingenfelter
29
May 17, 2004 10:40 PM
