Need detailed list on hx35/ht3b twins
Ok, i think im getting closer on this twin setup. i need a detailed list on what i need and what i need to do.
on my hx35, do i need to upgrade it to a hx35/40 hybrid or not?
on the ht3b, is a 26cm housing the one i need?
what size is the cold pipe?
what size is the hot pipe?
do i need a full 5" exhaust or can i get away with a 5" to 4" downpipe?
Thanks alot, im sure ill come up with more questions down the road.
Just me but i would go with the 35/40
Yes the 26 is the one you need
cold pipe is 4 inch
Hot pipe is 3 inch
i would go ahead and go 5 inch because you only have to go to your stacks with it
jmo
Jake
cold pipe is 4 inch
Hot pipe is 3 inch
jmo
Jake
Yes you can flip the manifold, but you ll need a spacer you raise the turbo. The hx35 should have atleast a 14 , I run the 16 non gated.
I also run a 5 to 4 exhuast. The 5 barely fits or barely doesn t fit, depending on how you look at it. I run to a 4 due to my 4 inch us gear decelarator exhuast brake.
I run black pvc for the air intake.
Ad removed site violation
Originally Posted by blackdiesel02
if you already have both turbos, how in the heck does all the other stuff cost over 2 grand?
bnradon.
Originally Posted by 97whiteram
So this is not a complete piping kit. Seems to me that would leave a lot of work left the consumer to complete the the system. And I bet that 5" doownpipe is NOT easy to build.
The dent is for extra firewall clearance.
$35 for the vband clamp, $8.99 for the flange and $10 for the 5" 45-angle exhaust pipe out of the scrap bin at the local truck shop.
brnaodn.
