How to turn up the boost on an HX?
Loosen the jam nut and turn rod end counter clockwise(to make the rod longer)if it doesnt have a jam nut you have to drill the 3 crimps,take the rod end off, install a jam nut, reinstall the rod end and set your boost. Its easy and its free.
Shorten the rod for more boost, but a boost elbow is by far easiest way to control boost at 35 psi. Just drill and tap your current brass elbow with a small set screw to limit boost "signal"=air pressure going to actuator bulb diaphram that pushes rod and opens wastegate.
If the rod is adjusted, it should be shortened. This will increase the tension on the waste gate making it harder to open.
Jim
Such an easy question and so many different answers. Here are some options:
Pull the elbow and use a 1/8 inch npt plug
block off the line
replace your elbow with an adjustable line
install a manual boost controller in the line
block off the line
