how to turn up boost on an HTT?
Old Jan 13, 2008 | 08:10 PM
JSCumms2000's Avatar
im sure its rather simple, but i figured id come to you guys first.. how out of the box its pullin 43 lbs of boost, and i know i can get more out of it.. i already have head studs, so i dont have to worry about that.. is it still an adjustable boost elbow, or do i open up the waistgate or whats the preferred method.. thanks guys... 71 series htt 62/14...
Old Jan 13, 2008 | 08:12 PM
SolarYellow05's Avatar
Here's instructions per HTT.
"On our High Tech 71/HTSS Series turbos, all you have to do is turn the nut on our wastegate actuator arm to shorten it (more boost) or lengthen it (less boost). Two turns approximate a 1 lb. pressure change."
Old Jan 13, 2008 | 08:20 PM
ook sounds good, i had a feeling it dealt w/ that... thanks..
Old Jan 13, 2008 | 08:26 PM
No problem.
O.T
16
Jan 14, 2008 02:47 PM
stealman1
Nov 9, 2007 11:07 AM
expressfish
18
Mar 11, 2007 04:28 PM
Bobcat698
Nov 8, 2006 11:20 AM
