How to tell if your truck is overloaded...
If you have to stop and remove your u-joint sheilds in the Home Depot parking lot because the DS yoke is rubbing it, then i think 3200lbs of concrete is a bit much
40 bags of concrete at 80lbs each, it was only halfway to the blocks but it squatted pretty bad, its a 2500, no overloads, no sway bar etc. and the entire 3200 was centered in a 4'x4' area in the center of the bed, not spread out over the entire bed like gravel would be.
i actually enjoyed the smooth ride for the 2 days the weight was on there!
If the u-joints shields are rubbing with that weight in the back, then they probably rub when you're hooked to the sled, don't they? Seems that the back would squat farther with a sled than 3200 in the bed.
I had 80 sheets of 7/16 osb plywood in the back of my mine this spring, the truck was still 2' from the rubber stops. Rode real nice then
. It has overloads on though.
1997 CTD 2500 4X4 ex-cab long box 238,000, gear vendors 8 speed overdrive, stage 5 TST plate, 4" exhaust, 370 injectors, full DTT auto trans, silencer MIA, X-monitor digital guages, 4:10 gears w/ limited slip,new style tow mirrors
. It has overloads on though.1997 CTD 2500 4X4 ex-cab long box 238,000, gear vendors 8 speed overdrive, stage 5 TST plate, 4" exhaust, 370 injectors, full DTT auto trans, silencer MIA, X-monitor digital guages, 4:10 gears w/ limited slip,new style tow mirrors
I just put 2 tons of dirt in the back last weekend and it only sat about an 1.5-2" lower. I also have the tow package with the overloads. I think the overload springs are the ticket when hauling heavy.
It did ride nice though.
