How much is too much....?
well this is prolly a repost but i've searched and came up with nothing that is specific to my situation.... as ya'll can see in my sig... 96 reg cab 3500 auto.... 100 full forward, afc forward, starwheel forward, 3gsk, 4in dp, BHAF....i just got through installing the methanol kit and have windshield washer fluid in there for now.... i have 1 1000ml/min nozzle in it now but will be addinf a 225 as to be around where most guys are with 2 625's... anyway i am seeing about 5 psi increase in boost.... i'm worried that i'm getting borderline for headgasket failure.... i can see 41psi before i activate the methanol and see 46 and would prolly keep climbing if i didn't let out of it.... i have a constant haze of black smoke at WOT and this is with a STOCK hx35... so whatever housing i have came stock on it.... wastegate is disabled.... should i make it work again to control my boost or will that make my egt's uncontrollable as i can see at much as 1500* preturbo (i let off at 1400 most of the time).... please help ma as i see an increase in boost but no decrease in egt's from the methanol..... well let me quit rambling...
Originally Posted by dodgeramrod
How long have you had all the previous mods? How is your tranny it?
well i backed it back to 35 psi and the egt's don't climb as fast but the motor dosen't pull as hard either.... i can activate the Meth/water and i see a 5 psi increase and the egt's increase just like before @40psi and no meth/water.... and this is with blue ww fluid and a 1000cc/min nozzle..... any other ideas? maybe i need to put in the 225 nozzle too?
Rather have that HX 35 at 35 or less and not blow it up. It is not worth the extra power you are getting when the turbo breaks and takes out other things.
Time to do the tranny and then get a turbo quick cause you are on borrowed time with boost numbers in the mid 40's!!!
jjrightmire1973
Nov 20, 2008 08:20 AM
