How much hp/tq does a Smarty add???
Old Apr 19, 2006 | 08:54 AM
jasonjones's Avatar
Question How much hp/tq does a Smarty add???
I tried doing a search and saw plenty of positive things about the Smarty, but I was just curious as to how much power it adds. Has anyone done a before & after on the dyno with a Smarty? What could I expect by adding a Smarty to my current combo..... ....besides a toasted stock clutch...
Old Apr 19, 2006 | 09:08 AM
HOHN's Avatar
Big response on the bottom end.
A dyno run will typically show 60+hp, and 175 lb-ft gain or so.
But there's a lot more to it than dyno power. Test drive one and compare it to an EZ or any other timing box-- you'll see how different it is.
The bottom end response of the Smarty is simply monstrous.
jh
Old Apr 19, 2006 | 11:29 AM
Marco's Avatar
The numbers are about what Hohn said. Give or take a few, it depends a little upon the truck / dyno.
The numbers alone do no justice to Smarty though.
To get the thing into the right perspective. A STOCK engine develops it's highest
Hp @ 2.7K Rpm. Let's say 230 ponnies. Torque remains somewhat stable arround 480 from 2K to 2K7 Rpm.
With Smarty. @ 2K Rpm the same engine does 240 Hp and 630 Ftlb.
( With odd numbered softwares, the ones with the timing )
The same power is availabel 7-800 Rpm SOONER.
Responsivness is what really matters!
Helps?
Marco
Old Apr 19, 2006 | 12:12 PM
Bob Wagner's Avatar
Old Apr 19, 2006 | 01:05 PM
HOHN's Avatar
Very appropriate slogan, there Bob Responsiveness is what it's all about!
Old Apr 19, 2006 | 01:13 PM
Geico266's Avatar
Great slogan, great explination by Marco (BTW, he is the inventor of Smarty) but how do you measure the WOW! factor?
Old Apr 19, 2006 | 06:14 PM
graphitecumnz's Avatar
Not that you want to wait over a week, but I'm supposed to get on the dyno on the 29th and should be able to get some numbers with some different combo's.
Old Apr 19, 2006 | 07:30 PM
kelownadiesel's Avatar
Helps?
Marco
what does the smarty offer to trucks that already run a timing and fuel box,like say a edge drag comp?What are typical gains to something like this?You have to be able to run the smarty without its timing advance somehow right?
Old Apr 19, 2006 | 08:26 PM
the even numbered softwares do not have additional timing... others will chime in with their comp/smarty results, IIRC, they like the combo.
Old Apr 19, 2006 | 11:29 PM
ncmech's Avatar
Marco, since I have a Bully Dog Torque Dog on my 2001 HO 3500 DRW 6 spd. Would the Smarty be something that would be beneficial to partner with the Torque Dog? Or should the Torque Dog be removed if the Smarty were to be used? Thanks for any info. The next few months I might be looking to improve what I have recently done to the Cummins. Dondi
Old Apr 20, 2006 | 12:09 AM
Ph4tty's Avatar
Marco has designed the smarty to work in conjunction with any of the aftermarket boxes, you just use odd settings with fuel only boxes and even with fuel/timing boxes. The thing is that a lot of folks turn their boxes off or remove and sell them after trying the smarty
Old Apr 20, 2006 | 11:05 AM
Marco's Avatar
ncmech,
the above sums it up rather well....
Old Apr 20, 2006 | 11:09 AM
RowJ's Avatar
Not exactly a before/After test....but dynoed from an EZ/TST stack to a Smarty/TST stack. Not scientific for a few reasons...but had enough comparable data from others to say there is 10 HP more than I expected... that I can't account for.
As said...not scientific results, by any means. And 10 hp difference is easily explained away by different time of day, etc...... but based on better performance from Smarty over EZ....10 hp over an EZ sounds about right??
I'm sure someone will do a back to back... on a stock truck, one of these days.
RJ
Old Apr 21, 2006 | 04:36 PM
jasonjones's Avatar
Thumbs up
Thanks for all the replys guys! Everybody seems to have good things to say about the Smarty!
My truck seems a little slow till it gets some boost built up. Judging by the few mods that I have in my sig, do you think the Smarty would wake it up?
Old Apr 22, 2006 | 12:53 PM
RowJ's Avatar
Based on reports from those that have tried my Smarty (5 sp and have 60-100 hp already added).... it will feel twice as responsive as the previous mods!!
RJ
