How Much Boost w/ a Comp
Old Nov 3, 2004 | 04:22 PM
dodgediesel4x4's Avatar
How much boost are yall running w/ an edge comp? My gauge max's out at 30 and I can burry that needle. I run my comp on 2x5 or 3x3 (can slip the clutch either way if I get on it) and mach 1.5's are on the way. I know I'm gonna upgrade my boost gauge soon when the injectors get here, but I am curious to see what yall are running boost-wise right now w/ a comp.
Old Nov 3, 2004 | 07:00 PM
BigBlue's Avatar
Should be around 35psi.
Old Nov 4, 2004 | 03:24 AM
dodgeram's Avatar
my regular comp and 275's gave me 37lbs of boost in 5th
the drag comp runs me about 45 lbs ........
Old Nov 4, 2004 | 01:14 PM
Stingerpup's Avatar
On my '00, I was getting between 37-42lbs depending on if I was on a grade or not.
Old Nov 4, 2004 | 08:17 PM
ratsun's Avatar
35+ it only a 35# gauge
Old Nov 4, 2004 | 08:40 PM
duke1n's Avatar
Hmmm at 5000' with comp only and boost elbow I would hit 30 psi on 5x5. With Mach2s, comp, and B1-2 I barely hit 38 on 5x5. I have some 4s coming and hope they will spin maybe 42-45psi. Does altitude have that much effect?
PS I have re-tightened all clamps a couple times so I doubt I have a leak?
Old Nov 4, 2004 | 08:57 PM
joefarmer's Avatar
About 72 psi from my Comp...
brandon.
(you may want to clarify your question or request only results from stock turbo users)
Old Nov 4, 2004 | 09:04 PM
BigBlue's Avatar
Old Nov 5, 2004 | 08:06 AM
RowJ's Avatar
duke1n
Altitude make a big difference...more than I would have thought.
I get 50 psi boost (PM3 on 9) at home..650'... and could only pull 41 psi in Colorado Springs...at 6000'.
RJ
Old Nov 5, 2004 | 08:43 AM
oscaroc's Avatar
36 psi with comp on 5x5 stock turbo. 4500 feet above sea level
dodgediesel
14
Dec 14, 2006 09:54 AM
MDMIKE
Jan 18, 2005 10:02 PM
NeedMoPower
Jul 12, 2004 10:04 AM
Cumminsdieselboy
Oct 27, 2003 07:36 AM
Wes C
Dec 24, 2002 12:28 AM
