How to get stock HX35 to spool up more quickly?
Old Dec 4, 2005 | 09:13 AM
Tiger Rag's Avatar
Truck is a 2001.5 6 spd with stock air box and true flow foam filter. I was curious as to what options there were to get stock turbo (hx35) to spool up more quickly. I have 4 inch exhaust and that coupled with the foam filter element seemed to help a decent amount, just curious if there were other things to try/think about to improve this some more. Seems a buddy's truck spools up very quickly. He has a uni filter plumbed like a BHAF and a Mad ECM. Didn't know if these were the reasons his spooled so quickly or if it had to do with his auto trans.
Thanks, Matt
Old Dec 4, 2005 | 10:01 AM
BarryG's Avatar
It is the MAD ECM. The fueling map in those lends to quick spool up.
Old Dec 4, 2005 | 10:30 AM
high country's Avatar
first off you are comparing an hx 35 with an hy so he does get a bit quicker just in the turbo but he is kicking your butt in the fueling and breathing, if you go with a mad ecm you too will see a big difference in spoolup
Old Dec 4, 2005 | 12:54 PM
mr T's Avatar
more fuel will get it to spool up quicker.....smaller turbine housing.....
ofcourse a bigger turbo will get the job done
Old Dec 4, 2005 | 01:02 PM
Whitmore's Avatar
I recently did the HTT exhaust manifold, I ported and polished it first, it made a huge difference in how quickly she spooled up
Old Dec 4, 2005 | 02:19 PM
Diesel-Dan's Avatar
You could go down to a 3.5" DP, like the older Magnaflow systems....but that would lead to higher EGT's if you started pouring on the fuel....and if you towed. BUT the 3.5 is probably good to around 350-375 HP or so....from my point of view! The smaller pipe will keep the heat in the turbo and lend to better low end responsiveness with out excessive restriction.
I helped out Rjohnson with his new HTT Manifold with his new HX-55 a few weeks ago. He drove on the turbo without the manifold and with. He said there was a noticeable difference with the new HTT. Heck...im sure he will see this thread and chime in on Monday...just wait! haha....
Old Dec 4, 2005 | 06:39 PM
HOHN's Avatar
You could try LOX injection into the exhaust manifold. It will help drastically with spoolup-- for a little while (about a nanosecond, hehe).
HOHN
24
Jul 20, 2009 09:34 PM
bjerauld
Jan 1, 2008 06:55 PM
natlchamp2k4
Mar 6, 2007 04:59 PM
Sarge1124
61
Aug 12, 2003 07:30 AM
