how to get 600 hp
Old Nov 17, 2010 | 10:21 PM
bassfishin's Avatar
how to get 600 hp
I am planning on building my truck next summer. I would like to have at least 600 HP. I was planning on installing an Airdog 150, replacing the power Puck with a comp, ARP head studs, and gauges. I just don't know what injectors and Turbo set up I will need. What other mods will I need to do? If it is possible I would like too be able too tow heavy loads with it. I mostly pull my bass boat but have rolled across the scales @ over 25,000 lbs. Before hauling farm equipment. Any info would help, the more specific the better. Thanks!
2001 2500, built auto. Tranny, 3" straight pipe w/ 6" stacks, silencer ring MIA, HBAF, Diablo Power Puck, and Smarty
Old Nov 18, 2010 | 06:47 AM
johnyb59's Avatar
some 240's and BD twins since you tow.
Old Nov 18, 2010 | 07:45 AM
rattlerbob5.9's Avatar
If you want to make 600hp AND use it for towing heavy as well you had better put 2 turbo's on your grocery list = twins. You will also find out if your "built auto tranny" in your sig is any good or just the next weak link.
Old Nov 19, 2010 | 12:59 AM
bassfishin's Avatar
Any more sugestions. Which turbos do you suggest. And please be specific, I am not up to date on injector and Turbo lingo. For instance, I don't know what 240's are. Thanks!
Old Nov 19, 2010 | 01:36 AM
Tate's Avatar
Better sit down and do some searching on the forums and educate yourself first. Don't go into this blind and blindly following peoples advice, it'll be an expensive lesson.
bigtruck
27
Jul 3, 2008 11:43 AM
ridofpwrstroke
21
Dec 19, 2007 12:53 PM
Mark Hodowanec
Sep 17, 2004 05:49 PM
dieselnewbie
Mar 19, 2004 11:23 AM
