How did you plumb you FP gauge?
Old Dec 19, 2006 | 08:41 AM
Ram1999's Avatar
How did you plumb your FP gauge?
I'm placing an order for a Fuel Pressure Gauge today. But, don't like to pay as much for 4' of braided tubing as the gauge.
ISSPRO has a plastic tubing kit for oil pressure which would be a higher pressure than my fuel pressure. But will it hold up to diesel fuel?
I could use copper tubing but worry about enginge vibration causing it to crack over time.
What did you use to plump your mechanical fuel pressure gauge???
I'm buying a steering column mount for it, so it will be right on top of the steering column.
Thanks.
Old Dec 19, 2006 | 09:31 AM
Moose10's Avatar
I used approx. six feet of 1/4" ID hydraulic hose rated at 300psi from a bulk spool at a local NAPA. If I remember correctly it was only a little over $2 per ft. I have a "T" fitting inline between the filter housing and the VP with a needle valve. Been running about 18.5psi at idle for over two years now....no leaks or problems. Oh, I also used Permatex liquid thread sealant on the brass fittings.
There's a couple pics in my gallery relating to the needle valve and such, but fyi, those pics are before the FASSII. That's why you'll see the old banjo bolts.
Old Dec 19, 2006 | 09:32 AM
mcoleman's Avatar
I used nylon pressure tubing with a needle valve at the VP44 and compression fittings. I opened the needle valve just enough to get the guage to work. It doesn't require much opening of the valve at all.
Old Dec 19, 2006 | 10:12 AM
infidel's Avatar
I've been using plastic oil/boost pressure type tubing on both my trucks and several others for about ten years without one problem.
Just push the small tubing though some 1/4" tubing to protect against kinks, cuts and abrasion.
I for the life of me can't understand why people feel the need to use high pressure or braided hose for a measly 20 psi max. The heavy hose must be a real hassle to route around especially if your gauges are in the A-pillar.
Old Dec 19, 2006 | 12:30 PM
Muddin_dude06's Avatar
I am using 1/4" ID hydralic hose made with the correct fittings on each end, I did it this way just because I DON'T like compression fittings. It was a little over $20 assembled at NAPA...
Old Dec 19, 2006 | 12:50 PM
Ram1999's Avatar
I placed the order.
I bought the ISSPRO tubing kit they sell for oil pressure gauges. It was $9.00 for the kit.
Also bought a ISSPRO 0-30# Fuel Pressure Gauge @ $39.75 and a steering column mount @ $29.90.
Everything with 2nd Day Air shipping was $95.00.
Bought it all at eGauges.com
Trooperthorn
Nov 20, 2010 12:52 PM
Artsi_L
Mar 2, 2007 12:01 AM
turbo dreams
Oct 26, 2006 10:58 PM
CSAGrey1
22
Sep 17, 2006 09:19 AM
Dieseljunkie
Aug 17, 2005 07:54 AM
