HOW BOUT THIS "BOX"--- 2003 Cummins
http://www.rpmoutlet.com/ds994603ins.htm
Over on the other "FORUM" the HP #'s look really good ;D. Look under "Dynoed Truck"
Re:HOW BOUT THIS "BOX"--- 2003 Cummins
The numbers look really good on that box.
However, I am pretty much sold on the TST once it comes out. It adds 150HP and 400lb ft torque. It also has a built in EGT and Boost gauge. Here is the link for more information:
http://www.tstproducts.com/powermaxcr.htm
Edge will also have their new one out shortly which sounds like it will be in the same power level as the TST and have the in cab controler with guages.
Nothing against TST but their controller looks a little "cheap" to me, going to go with the EDGE after it has been out for a little bit.
Are there any pictures of the new EDGE box? Also, from what i've heard, the TST does not increase the rail pressure like the current EDGE boxes do. The TST just adjusts pulse duration and timing. I'm interested to find out more info if anyone knows. All in all, I'd feel more comfortable knowing that the reliability of the common rail system will not be affected when i'm ready to get a box. I also agree that the TST controller looks a little cheap, but if it gets the job done and is more realiable I don't really care.
The current Edge Box called the EZ does just increase rail pressure yes. The new one coming out, don't know what name they are giving it, will play with the duration and timing instead of fuel pressure. But the cool part is that you can stack it with the EZ to increase rail pressure and timing and make some real power......... 8)
Edge controller here:
http://www.edgeproductsinc.com/Dodge...20Monitor.html
[quote author=Mopar_Mudder link=board=7;threadid=20997;start=0#msg197170 date=1066237771]
[/quote]
Great...Just when I thought I had my mind made up I find out about another great product!
Now i'm not sure which one to get. I guess time will tell after there are a few guinea pigs to test them.
On a side note...the new Edge box looks like the Apex-i fuel management units you see in riced out Hondas buzzing around.
[/quote]
Now i'm not sure which one to get. I guess time will tell after there are a few guinea pigs to test them. On a side note...the new Edge box looks like the Apex-i fuel management units you see in riced out Hondas buzzing around.
[quote author=RamDan03 link=board=7;threadid=20997;start=0#msg197176 date=1066238094]
[/quote]
Luckly not many ricers in my neck of the woods
[/quote]
[quote author=Mopar_Mudder link=board=7;threadid=20997;start=0#msg197188
Luckly not many ricers in my neck of the woodsUnfortunately they are everywhere around here. They also like to travel in swarms. Sounds like a pack of bumble bees.
i recently installed the volumizer 3 in my 03 and i am very impressed. i like it b/c you can change the hp settings with a toggle switch, stock-60hp-100hp settings. i purchased it from rpm outlet, it has 4 plugs, fuel sensor, map sensor, cam sensor, and the crank sensor
Volumizer is a spitting image of the Bully Dog box. To me anyway, they claim no affiliation. Many of which have given trouble (codes, bad miss etc). Check the return policy with either, oh and rail pressures with either of these boxes are higher than what the EZ does.
PEAKSTRYDE
Oct 11, 2007 04:20 PM
600 Megawatts
Jan 22, 2005 04:53 PM
vince1
Jun 6, 2003 12:22 AM
