Hot Rod Pump
Old Jun 18, 2005 | 11:41 PM
JAFAW's Avatar
Hot Rod Pump
What is this hot rod pump i read about?
What makes it a hot rod pump?
Where and how much?
Old Jun 19, 2005 | 12:26 AM
12vordie's Avatar
Read about where?
p-7100 or ?
Old Jun 19, 2005 | 01:28 AM
95ram's Avatar
I believe you are refering to a hot rod vp-44. It is a made with an HO pump. I know they change the plunger size and there are a few other internal mods. TST has them for about 1800.00 and I saw them at another place (cant remeber the name) for about 1600.00. From what I've been told by a couple differant outfits that make them they are supposed to add about 60RWHP.
Old Jun 19, 2005 | 08:05 AM
600 Megawatts's Avatar
Muted User
Yes it combines the best of both HO and SO VP-44 injection pumps. It has the large volume plungers of the SO and the high discharge pressure of the HO. Its about $300 more than a replacement VP-44, so to me it makes sense to do this when you have to change the pump anyway. When you are allready spending $1,500 and have the whole thing apart, whats another $300????
KP
Old Jun 19, 2005 | 04:41 PM
PourinDiesel's Avatar
What are the other changes?
Old Jun 19, 2005 | 04:52 PM
apache's Avatar
Thell never say, trade secrets. My pump guy says he wont use fuel plates or injectors cause they just make a bunch of worthless smoke, but he can put me in the 250 to 300 hp range no problem on a otherwise stock engine for $800 or so, including timing and pump seals. He is one of few as I understand that has one of the trick pump machines that cost him some 30 grand or so. The things very impressive. He sure did a good job on my 93`s pump. made a tire burner and a beliver out of me.
Old Jun 20, 2005 | 08:19 PM
JAFAW's Avatar
If you put the vp44 hot rod pump in the truck will the stock injectors handle it or do you need big ones?
Old Jun 20, 2005 | 08:58 PM
Muted User
Sure stock injectors will work fine with it. And then when you go bigger, (which of course you will, its only a matter of time) you will really feel it.
KP
DieselRebel24
Feb 26, 2012 09:30 AM
Badd Dogg Guy19
Jan 18, 2008 09:19 PM
Strjock81
16
Dec 12, 2007 09:53 AM
edwinsmith
Apr 14, 2006 03:53 PM
duallydave
Aug 7, 2005 09:38 PM
