Holset HX50
Old Apr 3, 2008 | 07:11 AM
91rangerturbo's Avatar
Holset HX50
Is anyone running one on a 24 valve truck? What supporting mods do you have? What modifications did you have to do for the install? I am thinking of switching from the HX 35 to a HX 40 or HX 50. Thoughts? Suggestions?
Old Apr 3, 2008 | 07:40 AM
haloman's Avatar
It would be laggy on your auto without the right housing
Old Apr 3, 2008 | 07:41 AM
what about the master power 66mm turbo from Piers?
http://www.pdrdiesel.com/products/Ma...ns-952-26.html
Old Apr 3, 2008 | 08:52 AM
HOHN's Avatar
It would be laggy even WITH the right housing!
Old Apr 3, 2008 | 08:57 AM
Thanks for the input. After doing al little research i am going to pass on the HX50.
Is there anyone running a Master Power 66mm?
Old Apr 3, 2008 | 10:18 AM
Big Blue24's Avatar
If you search it, many claims that it has a small shaft and breaks the first time you bark it. Some think it may live in a twin setup but maybe not.
Just follow me to the way of cheap third gen turbo setup. It cost me less than 500 bucks total and was a fun conversion. It helped in the power and egt department. Has a silencer ring for those long trips, spools lightning fast on the street.
Old Apr 3, 2008 | 12:11 PM
Isn't a third gen turbo a HY35? HE351? I know there basically the same turbo correct?
Old Apr 3, 2008 | 01:41 PM
haloman's Avatar
HE351 is the turbo on the 04.5+
Old Apr 3, 2008 | 01:48 PM
that's what i thought. What the difference in the turbo's on the third gen's? There all hx35 or hy35 with different compressor housings or different turbine housings depending on what style truck correct?
Ramrod90
Feb 3, 2009 01:39 AM
beaver76
Jun 22, 2008 11:43 PM
03dodgeoffroad1
Jul 9, 2007 01:40 PM
Rebel
Apr 20, 2003 01:57 PM
