Holley blue install.
Old Oct 20, 2006 | 06:28 PM
ramroamer's Avatar
Looking to plug in hot wire with hot source while ignition is on. Black diesel recommended power saet fuse. (as I do not have power seats). THanks by the way. Do I have to cut the wire to that fuse or is there a simpler way to get a hot source, w/o sorting through wire cluster. I'm lost under there. Any ideas?
Old Oct 20, 2006 | 06:50 PM
scottsjeeprolet's Avatar
I used a relay and i highly suggest you do! that way the pump will get full 12v from the battery.
i tapped the stock LP hot to trigger the relay and ran a big wire from the bat-relay-pump. Works great hardest part is gettin to the LP wire, need 3 hands.
Yes the stock LP is still running. 23 idle and 15wot. Look at the bottom guage.
Old Oct 20, 2006 | 10:32 PM
ramroamer's Avatar
Install success!!!! Plugged pump into power seat fuse, only problem seems to be it is hot all the time. 19 psi @ idle, thanks for info. I'll figure it out.
AlCorr
114
Feb 11, 2009 02:32 AM
Texaschevelle
26
Nov 16, 2007 08:08 PM
SmokinFive9 4x4
13
Nov 8, 2004 09:46 AM
SjLingenfelter
Jul 5, 2004 09:56 AM
ppsi
20
May 15, 2004 10:55 AM
