Holley Blue is in!
now just a thought , i wonder, ive got some blue pumps on the shelf and i need one for a dmax or 3, they cant have over 12 psi (lb7) and (10 lly and lbz). I wonder if i can compress that spring or just get another one... hmm ill let you know if it works!
big blue are you saying it would be smart for me to cut half of it off.... are you saying i dont do things in moderation... thats okay i see how it is, ill just buy me a FERD!
just kidding! Ill Try That!
Later yall
Later yall
How is the noise factor with the Holley blue pumps mounted to the frame?
My carter makes a loud growl when you turn the key on which is very loud, but once the engine starts, you can't hear it anymore.
Can you hear/feel the Holley while the engine is running?
Thanks
Thanks
there is a hole in the inner side of the '01 frame around 8 inches aprox.
i put the motor in there, moved the holding bracket to the top of the pump, so now the motor is in the frame, and the pump side sticks out so the fuel lines go by vertically, dont know if i make any sense, but the two holes on the bottom of the frame, just aligned with the holley bracket....
and yeah, my brothers and cousin both complain that its too loud, i can hear it with the window down up to 30 mph
We use this truck for short trips... (on the field) so yeah its noisy (on the frame)!
AlCorr
114
Feb 11, 2009 02:32 AM
Texaschevelle
26
Nov 16, 2007 08:08 PM
