High Perf Second Gen
Old Nov 1, 2004 | 05:09 PM
mhuppertz's Avatar
I know this has been covered before in pieces, but I have a friend with a 2nd gen stocker who want's a step by step shopping list to step up the performance of his 5 speed truck. I think I could help him pretty well if he had a 1st gen....
Thanks!
Mark
Old Nov 1, 2004 | 05:12 PM
Forrest Nearing's Avatar
12v or 24v?
Old Nov 1, 2004 | 07:09 PM
mhuppertz's Avatar
Oh, sorry. 12v
Old Nov 2, 2004 | 09:17 AM
HOHN's Avatar
12V:
#10 plate
191 DVs
4K GSK
370 Injectors
Piers twins
That should be enough to get him started. He MIGHT need an upgraded trans to hold this power level
JLH
EDIT: fixed doofus mistakes
Old Nov 2, 2004 | 10:54 AM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
Originally posted by HOHN
12V:
#10 plate
191 DVs
4K GSK
370 Injectors
Piers twins
That shoulbe get him started. Hi MIGHT need an upgraded trans to hold this power level
JLH
Dual disk clutch from South Bend
1 3/8" input upgrade from South bend also for the NV4500
That ought to do him quite well
Old Nov 2, 2004 | 02:30 PM
what year truck is it? the later pumps make more power and will require more clutch/turbo for given fueling.
I'm happy w/ my combo... sure wish I could afford twins and a dual disk clutch, but I'm still walking away from lots of other modded diesel trucks on the highway.
Old Nov 2, 2004 | 05:58 PM
NORM's Avatar
60# exhaust springs at 4 k?
Old Nov 2, 2004 | 06:05 PM
if you want to rev it to 4k, then yes, 60# intake and exhaust springs!!!
I've got a 4k GSK... never installed the valvesprings. I shift at 3400-3500.
Forrest
Old Nov 2, 2004 | 06:51 PM
mhuppertz's Avatar
From what I understand at 4,000 rpm the CTD B develops a destructive harmonic issue that can cause catastrophic failure.
Old Nov 2, 2004 | 07:51 PM
I've accidently hit 4k RPM before w/ stock valvesprings... no damage.
the problem w/ high RPM is the valvesprings aren't strong enough to close the valves quick enough, and the valve and piston try to occupy the same space... then bad stuff happens.
Forrest
Old Nov 2, 2004 | 07:53 PM
mhuppertz's Avatar
I think it's sustained 4,000 rpm that blows them up, even with the 60* valve springs.
Old Nov 2, 2004 | 07:56 PM
never heard of that before... the big boys wind them to 4k++ quite often. (high HP drag racers and pullers)
Forrest
Old Nov 2, 2004 | 09:47 PM
dalee's Avatar
DOES ANYBODY MAKE A 3500RPM KIT AND WOULD THIS BE OK WITH STOCK SPRINGS. IF NOT HOW WILL THE 3K KIT ACT COMPARED TO STOCK
Old Nov 3, 2004 | 06:52 AM
a 3k kit on a 215 pump will rev to 3400-3500... on a 160-180 pump, go w/ the 4k GSK and just watch the tach... probably won't go any higher than 3400...
I've got a 4K GSK on a 215 pump. been on there for ~70k miles. stock valvesprings have ~235k miles on them. just watch the tach.
Forrest
Old Nov 3, 2004 | 12:08 PM
mhuppertz's Avatar
His 2nd gen is a 1995. So, a plate, a spring, what else?
