help with turbo and clutch
Old Jan 18, 2009 | 01:07 PM
qssc's Avatar
for the truck in sig. i am getting ready to purchase my gauges (fuel pressure, pyro, boost), jammer stage 5's, clutch then turbo. where do you think are the best places to buy these at the cheapest price? do you all recommend gettin the injectors pop tested or you think they will be ok? truck has 140k miles. and im not sure what clutch or turbo to get. and if i am easy on it do you think the stock turbo will be ok until the turbo comes? thanks for the help. also, how much will a smarty help out. buddy has one sittin around i can get for cheap.
Old Jan 18, 2009 | 09:54 PM
estrada5.9's Avatar
id do some research on the this site first. i think the reason no one has answered you yet is cuz everything you asked has been answered 50 to many times.
Old Jan 19, 2009 | 07:54 AM
Krob's Avatar
I'll be nice and bs with you a little
South Bend Clutch is probably your best bet.
I have a Quadzilla Cammander and like it except for the fuel pressure sensor issue which is supposedly now fixed. I dont think they are still making the cammander now i think they just came out with something new with more capabilities. However i think i like the look of analoge gauges better.
Cant help you with Turbo, or injectors though.
I'd start using the search function and see what you can find. Your questions have been asked alot.
Hope it helps
Rob
Old Jan 19, 2009 | 04:05 PM
Flatbed24v's Avatar
look into F1 Mach injectors. They are more expensive but worth it for the quality you get on them. Things like injectors, turbos, and clutches you don't want the cheapest, cause you may have to buy them twice. I would get the quality stuff as cheap as you can, then you won't have to worry about it once the good stuff is in there. Just my two cents
Old Jan 19, 2009 | 07:07 PM
6WHEELER's Avatar
I'm not sure what the hp rating is for the jammers but,
As for the clutch. South Bend Clutches. upgrade to the 13in clutch and match to the hp you think you will have.
as for injectors. F1 Mach injectors. Not cheap but worth it.
as for turbo, match to the injectors for spool up an cooling ablity
All of the above need to matched to what you plan on doing with the truck.
IE:towing with big injectors, and a big slow spooling turbo can be painful, smoky and hot.
I ran F1 mach 2's"105hp" injector and a stock turbo for three yrs with no problems, it would get hot if i was playing hard but never had any problems towing.
A smarty will stack with your drag comp just use the even number setting for fueling only. It helped the bottom end fueling and the drag comp will take care of the top end. It has a trouble code scanner thats nice if you don't have one.
like Flatbed24v said, pay for the good stuff the first time it will save you in the long run.
Old Jan 22, 2009 | 01:16 PM
dstad's Avatar
im gonna say chech out www.sourceautomotive.biz . ok there site mught not have exactly what you are looking for but call the 1-800 number and ask for bill or rip and then tell them ecactly what u want and they could work u up a quote. if u read about them they "refuse to be under sold" and they mean it
hot_runner58
Dec 7, 2010 02:34 PM
Ada381
Feb 10, 2008 07:58 AM
13ALPHA
Aug 14, 2007 09:04 PM
abarnar1
Jun 23, 2006 09:08 PM
ddestruel
Jul 25, 2005 05:14 PM
