HELP!! stuck bolt
Old May 30, 2007 | 08:23 PM
01 Dwhite's Avatar
HELP!! stuck bolt
i just bought a j hook from tst and i went to install it but as i was trying to remove the bolt off the exaust housing and it was extremely hard to loosen and then when i turned it once the wrench striped one of the sides so now i have it out a little but i dont know what else to do to get it out..the kit comes wit a new bolt so if i can get the old one out i will be fine..
thanks Asa
Old May 30, 2007 | 08:39 PM
CTD01's Avatar
Bolt
I would try to get the box end on there if not use a line wrench also try heat with theses tools. You can use a bigger turbo with all the stuff you have done, I wouldn't waste your time with a j hook.
Old May 30, 2007 | 08:47 PM
01 Dwhite's Avatar
ya i kno i need a bigger turbo but right now im just nursing my transmission along i need to rebuild it before the turbo..but i will try to get it off but in the future what are yalls thoughts a 62/14 or 64/14 its an auto so should i just go wit the bigger one?? i have plans on the smarty and bigger sticks
Old May 30, 2007 | 08:54 PM
CTD01's Avatar
turbo
Well I have an htb2 62/14 and a 12. I have 150 nozzles and egts are ok, actually better with the 12 housing. I would upgrade to a bigger turbo if I was going to get anything bigger than the 150s. Tranny wise I am still on a stock tranny, I dont pound it all the time though and when I do my converter is LOCKED. It works but doesnt like level 6 much . I am getting a dtt in the next week or 2 so I can drag race and really feel all the power I should.
Old May 30, 2007 | 10:11 PM
Clayten's Avatar
DTR's Toad Wrangler
If you have access to a welder take a nut and weld on the inside of the nut to the bolt. Let it cool till you can touch it with your hand. Get a wrench that will fit and it will come out.
birdboy
Dec 12, 2018 09:02 PM
FordTrax
Apr 18, 2014 08:47 PM
birdboy
Apr 21, 2012 09:44 PM
Baja
Jan 29, 2008 08:17 PM
04ctd
Sep 14, 2004 04:43 PM
