help with piers plate
Old Mar 23, 2007 | 04:12 PM
b.white's Avatar
adjusted governor arm to touch the very bottom of plate when set in the middle position falling on its face no power what so ever but how do i get the arm to travel out to go full forward with it. it comes out then up and never touches plate f-forward what should i do
Old Mar 23, 2007 | 04:45 PM
Clayten's Avatar
DTR's Toad Wrangler
Put it full forward, adjust arm to approx. bottom of plate go for a run. If you are under 34 lbs of boost your arm is too high. if above you are to low.
Old Mar 23, 2007 | 06:23 PM
infidel's Avatar
Did you remember to slide the AFC housing full forward before tightening it down?
Old Mar 23, 2007 | 07:18 PM
b.white's Avatar
how would i go aboute putting my afc full forward do they mention this in the piers tech page
Old Mar 23, 2007 | 07:56 PM
Clayten's Avatar
DTR's Toad Wrangler
Loosen off the bolts holding down the AFC put a screw driver at the back pry lightly to the front, tighten bolts back down.
Old Mar 23, 2007 | 08:16 PM
b.white's Avatar
thanks for the help i will check and adjust all my settings first thing tomorrow ill get the old girl anialating tires soon enough
b.white
Old Mar 24, 2007 | 05:36 PM
b.white's Avatar
today i went back and retraced my steps discovering that the problam was that i was not pulling up on the fuel shut off there for when i adjusted the arm it was going under the plat fixed problem and wow this thing came alive 10 x better than before thanks for the help again
royta
Sep 16, 2005 03:31 PM
360ramcharger
Jul 6, 2004 10:15 PM
Dufrain
Jun 7, 2004 11:25 AM
drawson
29
Mar 26, 2003 10:48 PM
Jetpilot
83
Oct 17, 2002 04:02 PM
