HELP! 12mm stud install
Old Mar 29, 2008 | 11:51 PM
ncdodgeman20's Avatar
Question HELP! 12mm stud install
hey guys ia got a problem i am reinstalling my new oring head with 12m studs well i left the studs out put the h/g on the block then lowerd the head down on to the block and then went to install the studs well i got all of them in but the back four the last to on the exhast side and the very last 2 at the back of the head i have tryed everything so could someone help me out with how to get the last for of these studs in thinks mike!!!
Old Mar 29, 2008 | 11:56 PM
1-5-3-6-2-4's Avatar
theres 2 plugs up in the cowl above the back of the engine....pull them first. that may do the trick. if not I removed mine a weeks or so ago and had to put a prybar on the edge of the cowl and just give it some lovin' to get the last 2 out. probably have to loose that insulation from the firewall too. I pulled that stuff off the 1st time I set the valves. all that junk dust floating down on the engine not cool.
Old Mar 30, 2008 | 12:05 AM
yea i got the little plugs out i mean i have tryed every angel to get them back studs in but not work so take a pry bar and pry up on the cowl is that what ur saying??
Old Mar 30, 2008 | 02:25 AM
thats what I did to get them out this last time. when I installed them then all went in with no prying, but it was pretty tight. granted when I took them out a few weeks back I was in no mood to pussyfoot around so I went straight to the 42" prybar and they came out fine. nothing broke.
Old Mar 30, 2008 | 04:18 AM
2141pete's Avatar
I didnt have a bit of a problem with mine, i didnt even pull the plugs. Is there something else in the way?
Old Mar 30, 2008 | 09:50 AM
Smile
thinks for all the help guys i bout to go start back on it no there really aint nuthhin eals in the way but thinks again
Old Mar 30, 2008 | 11:51 AM
JIT's Avatar
JIT
loosen the cab mounting bolts and lift the cab an inch or so. It wont hurt a thing and then you can just tighten everything back up!
dodgediesel
Sep 1, 2010 06:46 PM
74dart
Jul 7, 2007 07:58 PM
SilverSootXpres
May 8, 2007 08:53 PM
65fury
Dec 29, 2006 05:33 PM
blackcloud
Jan 17, 2006 12:41 PM
