headlight upgrade ?
Old Aug 28, 2017 | 12:07 AM
oldblues's Avatar
Question headlight upgrade ?
hi all !
looking to upgrade my headlights , lenses getting dull soooo ,what to buy ?
so many choices ????
thank you !
98 quad single bulb now
Old Aug 28, 2017 | 06:15 AM
Greg Reed's Avatar
I read on a headlight thread on one of the forums, where Daniel Stern (daniel stern lighting) recommended Dorman headlights. This was for a Sport conversion. The Sport conversion has been popular. The Daniel Stern harness is a good addition. It seems factory Sport headlights are almost un-obtainable now.
Old Aug 28, 2017 | 08:48 AM
BarryG's Avatar
Do the sport light upgrade. X2 on Daniel Stern harness. Top quality harness. I used depo lights. I believe Geno's Garage sells them. As good as oem no but I had no problems with them and they were a fraction of the price of OEM. When I did mine years ago oem sport lights which were still available were about 300 a side. The depot were 140 a pair. No idea what they are now though.
Old Aug 28, 2017 | 10:18 AM
Dieselbuilder's Avatar
sport headlight buckets and led lights works great on mine the old ones where so bad might as well turned them off to drive at nite
Old Aug 28, 2017 | 10:19 AM
cougar's Avatar
I did the "sport" light conversion a few years back. Even with hi wattage bulbs I can't say it's a great improvement. Do the HID conversion. Expensive? Yes, but it seems to be the best option for these trucks. Unless you like lots of auxiliary lights.
Old Aug 28, 2017 | 04:44 PM
Led lights in high and low but when the high is on both high and low are on both lights it makes for a mighty bright lite 130 dollars for both lights only problem i have is the day light running lights run low voltage on the high side but with led it only takes a small amount of power to light them up so soon as you jump in the truck just turn the lights on low
Old Aug 28, 2017 | 09:58 PM
torquefan's Avatar
Do you find that you have a well defined beam pattern with the LEDs? I put LED bulbs in the high beams of my Sport lamps, then shone them against a wall so as to aim them. Was disappointed to see no beam pattern on the wall, just random light. Same thing out on the road. They throw out a fair amount of light, it just seems to be all over the place. Is that to be expected?
Old Aug 28, 2017 | 11:18 PM
No defined beam but bright the wifes car is led but uses a projection setup to get the beam you like , compared to me old lights no contest it lights up the road as well as both sides of the ditch
Old Aug 30, 2017 | 09:50 PM
torquefan's Avatar
Thanks for the reply. They do seem to light up the road anyway. I don't think I'll rush to upgrade to projectors right away, I'm still pretty happy with the Sport lamps. I'm sure I'll get used to the LEDs.
Old Aug 31, 2017 | 10:49 AM
cougar's Avatar
I've only found LED's to be bright when your staring at them. As far as putting light down the road, no. Go with HID's.
Old Sep 14, 2017 | 11:34 AM
Midnite's Avatar
How much do the stock fog lights help?
Old Sep 14, 2017 | 02:25 PM
BILTIT's Avatar
Projector HID, only lights to get.
2nd Gen Dodge Ram HID Projector Retrofitted Headlamps
Old Sep 20, 2017 | 09:32 AM
Midnite's Avatar
Anyone?
I have all the pieces necessary to add on stock fog lights to my truck, but was thinking aftermarket LED units with a wide flood pattern might be better.
It's hard not to want to use what I've already got though.
The HIDs look interesting, but they're too pricey for me.
Old Oct 18, 2017 | 11:18 AM
PaulDaisy's Avatar
I have stock fog lights. They help but not on the highway. Their beam pattern falls in shorter than the low beam on the main headlights, and provides even illumination to the road. Useful on forest roads for me, on the highway, not so much IMO.
Old Oct 23, 2017 | 10:05 PM
04ctd's Avatar
don't the Depo Lights fail to seal & leak/fog up eventually?
there are two questions:
-what light assembly (brand/sport/non sport/OEM/Depo/eBay)
-what to put in there to create the light (LED/HID/Halogen)
i have the OEM lights in my truck, they are brown/dirty, can prolly clean them up,
should I just polish them (won't leak & fog up) and just put HID's in there?
links please, the link above is to a $500 set of lights, that's not reasonable.
