Head Torque ?
Old Mar 24, 2006 | 06:11 PM
Abbynormal's Avatar
Head Torque ?
Question. Before I start really modding this 12V I am going to get timing bumped to 15.5 or 16*, adjust valves and Kill the DP. With 135,000 miles I have never had the head torque checked. Before I adjust the valves I am going to torque the head. Whats the procedure for this with a stock gasket ? Do you back off first, then tighten back up ? How many pounds should they be torqued to ?
Old Mar 24, 2006 | 11:16 PM
Abbynormal's Avatar
Boring question huh ? I found the diagram of the tightening order. But what torque reccomended for all stock bolts and original gasket ?
Old Mar 24, 2006 | 11:32 PM
Jaxn51's Avatar
I would like to know as well. Maybe the veterans are out tonight, but hopefully tomorrow someone will answer.
Old Mar 25, 2006 | 02:18 AM
4doogie's Avatar
I wana say 96ft lbs, but im gona let someelse back me up on that before i tell you that
Old Mar 25, 2006 | 09:33 AM
ratsun's Avatar
I'm pretty sure I was told by Piers to do a line re-torque to 120 when my HG on the 24V started seeping. Start at the front and run down the head in a line then back to you on the next row then back up and so-on. I would shoot them a email or call them to confirm the torque # or find a FSM the # will be in there
Old Mar 25, 2006 | 02:26 PM
Abbynormal's Avatar
Question
Bump. Anyone know proper head torque and procedure.
Old Mar 25, 2006 | 03:49 PM
Starting with the bolt between the #3 and #4 valve covers, you go clockwise.
3 steps:
First - tighten all bolts to 66 ft#, then go back through and recheck.
Second - tighten the bolts that go through the rocker stands to 89 ft#, then go back and recheck.
Third - give all bolts another 90 degrees while grunting heavily.
Old Mar 25, 2006 | 05:21 PM
PourinDiesel's Avatar
Lube the threads with a light coat of thin clean motor oil or wd40 before torquing. This will ensure proper torque.
Also: do not flood the holes with oil.
blueberry
Feb 7, 2007 05:34 PM
Conn
Dec 29, 2006 06:30 AM
Dusty Ratcliff
Apr 10, 2006 07:35 AM
MADSEN
Oct 7, 2004 09:43 PM
OT-OF-Here
Aug 7, 2004 07:56 PM
