head removal
Old Mar 15, 2006 | 06:28 PM
judge88's Avatar
head removal
im gonna be removing the head on my dads 02 tommarrow. does anyone have any links or instructions on how to do it. im removing it because he getting ready to bomb the hell out of the truck and hes getting the head oringed. thanks justin
Old Mar 15, 2006 | 07:42 PM
Mike Holmen's Avatar
The Guru
Its pretty easy job, its just lots of work. A couple hints is that the back near the firewall, there are several pushrods that will only come out if you take out the plastic plugs in the firewall. Number your push-rods and rocker arms. Try to make sure that they go back together the same way that they came apart. Number your injector lines and try to remember how they come off. They are kinda tangled up and reminded me of a chinse puzzle. When removing the head, unbolt the fuel return banjo on the back of the head. If your gonna o-ring the head, you should also get some head studs. Clean-up the engine block really good, I used a buffer wheel on my grinder. You might want to buy a truck service manual as your gonna have to prime the injectors unstart-up. Torque the head-up to the manufacturer settings. Retorque the head in the morning before start-up as the gasket will compress over night. Do several re-torque before running any big boost numbers.
Old Mar 15, 2006 | 07:55 PM
Timinva's Avatar
DTR Advertiser
Justin give me a call if you run into problems. It is very straight forward but time consuming to do right. Have at least two other big guys or a cherry picker, that head is heavy and you have to be real careful with the o rings. Tim
Old Mar 15, 2006 | 09:16 PM
judge88's Avatar
thanks for the replys. tim if i get into trouble ill give you a call. im gonna do the twins for his truck and injectors but he still needs to bring it down to you for the tranny so ill tel him to call you to set a date up. i bet it will be the only truck running twins and mach 7's on a stock tranny youll ever see. thats if the tranny holds up enough to make it down to you.
Old Mar 15, 2006 | 09:46 PM
The Guru
It wont last. Mine last one outing. Not even 50 miles. I had a valve body and converter in mine. A couple 50psi runs, a stocker doesn't even have a chance.
Old Mar 15, 2006 | 10:57 PM
torquefan's Avatar
The injector lines come off in 2 bundles. Don't separate all the individual lines. Just unbolt their brackets from the engine, and leave the brackets on the lines.
As was mentioned earlier, don't forget the fuel return line, it's a banjo fitting right dead center on the rear of the head. You can't see it, but it's there.
HUNTINNUT
Jul 27, 2013 11:40 AM
trik396
Jun 1, 2008 07:04 PM
inline6359
Sep 9, 2006 06:32 AM
getblown5.9
23
Aug 18, 2006 08:22 PM
Copenhagenjunkie
24
Jan 27, 2006 11:23 AM
