Head gasket
Old Feb 23, 2005 | 04:27 PM
Jambbii's Avatar
Red face Head gasket
Well I noticed a puddle underneith my truck today. Checked it and sure enough it was coolant. Its leaking on the passenger side above the oil cooler. Checked the oil and its clean. Looks like its been leaking for a while and I never noticed it. Anyways I was wondering about the marine head gasket. I know its thicker and will possibly make for harder starts but that is no biggie for me. Would this be an alright combo with stock bolts for rigtht now then upgrade to studs? I am on a tight budget right now and I am going to take it easy on the truck for a while.
Old Feb 23, 2005 | 05:30 PM
QuadZillaTruck's Avatar
Doing research on this now for me
My 2cents; I have about the same engine setup..I'm looking into oring and ARP bolts..
Many say DON"T reuse the originial bolts..because they have streched..They have a gauge to compare to for this..but despite being on a budget too. I'm not taking the chance, and want this weakest link to be as tough as I can get it this ONE time so I don't get out in BFE where no one knows about this kinda stuff, can't get it and have to tow or live in some area waiting on parts...
Know that it is not good news, but its the safest news..still checking on the o ring stuff..hope it may help
Old Feb 23, 2005 | 07:09 PM
thumper 549's Avatar
Cummins has had problems with head fastners seince the "Big cam 350" yes there is a measurement......just dont,,throw them away.Once used there is no more stretch left,so they break.
Old Feb 24, 2005 | 12:34 AM
Jambbii's Avatar
Im thinking if it worse comes to worse, to just buy replacement headbolts for now. I am still wondering about gaskets I have searched around and came up with no real conclusion. Marine headgasket , stock or what.
Anny suggestions?
Old Feb 24, 2005 | 07:32 AM
ask don m on the board here
Old Feb 24, 2005 | 03:21 PM
herb's Avatar
mine is being replaced at Cummins service center now. They told be they always change head bolts when they remove heads. (65.00 for a set from Cummins)
Old Feb 25, 2005 | 01:44 AM
joefarmer's Avatar
I tried to limp by with new stock headbolts after oringing the head since ARP wasn't quite done with their studs yet. I suggest doing it right the first time. You're pushing a good amount of fuel for the 14.40 quarter mile times in your sig so I would recommend head studs from a reputable company- if you don't feel like replacing the bolts and head gasket again.
brandon.
Old Feb 25, 2005 | 05:38 AM
herb's Avatar
was told by Cummins today that there is a service bullitin down on my engine changing head bolt torqe from 66 lbs to 77 lbs
Old Feb 26, 2005 | 01:44 AM
Jambbii's Avatar
Is arp the only people that offer head studs? I may be able to get them at cost (whatever that is). Also, I might be able to o-ring the head for real cheap while getting it decked, should I go this route?
Old Feb 26, 2005 | 09:06 PM
joefarmer's Avatar
From the Cummins Manual in the 2001 FSM:
"Cylinder Head—Bolts
Step 1 59 ft/lbs
Step 2 77 ft/lbs
Step 3 Verify 77 ft/lbs
Step 4 Rotate All Bolts 1/4 Turn"
The 1/4 turn is estimated to be around 125 ft/lbs.
I'm not sure what your Cummins shop meant when they said from 66 to 77?
brandon.
Old Feb 26, 2005 | 11:07 PM
Fueling around's Avatar
I've got photos of a NEW Cummins bolt that snapped on a 120 lb re-torque. Glad I ordered the studs.
FWIW
My brother had head gasket troubles on the 4 cyl turbo diesel on his snow blower. After a few replacements they (JD) finally told him of a service bulletin that increased the torque around 10%. No more blown gaskets.
Old Feb 27, 2005 | 05:13 AM
herb's Avatar
Step 1 59 ft/lbs
Step 2 77 ft/lbs
brandon.
said previous torque specs called for 66 lbs and been changed to 77 (pus 90)
ted_pulliam
Jul 16, 2009 11:33 AM
wildchild97
Sep 25, 2007 02:44 PM
blueberry
Feb 7, 2007 05:34 PM
Conn
Dec 29, 2006 06:30 AM
MADSEN
Oct 7, 2004 09:43 PM
