Has anyone made their own stake rack sides/back?
Old Jun 6, 2005 | 06:02 PM
JoeDiesel's Avatar
Question Has anyone made their own stake rack sides/back?
Was thinking about constructing drop-in stake-rack sides and front/back for my '02 2500 - Need to haul a bunch of boxes from TX to NY - no serious weight - just household goods.. Most of the stuff I find online looks like 1X6 rails (front/back) with 2x2 uprights or something similar - has anyone had any luck fabricating a rack themselves? Would really like to be able to load up to the roof level of the truck but really cannot without side/back supports. Also wondering if anyone makes a hardware kit of brackets that I could just purchase and then cut the lumber to fit - any thoughts?
Old Jun 6, 2005 | 06:43 PM
Redleg's Avatar
If you want to save headaches, get the more expensive star-drive screws from the lumber store. They are hardened and self tapping. They go into pine like butter. A good drill will push them right through oak without snapping.
Old Jun 6, 2005 | 10:00 PM
Mopar1973man's Avatar
I made a set of racks but I used aluminum stakes and bolted on the 2x4 using 1/4" bolts. They are extremely strong and don't rattle except over rough roads. Great for hauling 1 cord of firewood.
Old Jun 6, 2005 | 11:17 PM
upersleder's Avatar
i made some for my 1st gen, i'm not sure if the pockets are the same on the 02 because mine has rail caps, which i have yet to look under, but i put pieces of 1X2" tubing into the pockets, welded a nut on the soutside with a hole on the inside, bolted it thru the hole in the pocket with a washer, welded 1/4" X2" flat stock to it and screwed 2X8s to them. you can make a simple slide on back by using flat stock with slits which slide into each other also.
Old Jun 8, 2005 | 08:49 AM
wgingg's Avatar
i made some with 2x4 stakes that i shave down to fit tight the screwed a sheet of plywood so its a half inch off the rails. works good i just use the bolt on hinges so i can put each piece on by itself and just drop a couple pins to hold it all together
Old Jun 8, 2005 | 11:43 AM
JoeDiesel's Avatar
Man, great ideas - thank you! Think I'll give it a go next week.. now to find a cheap flatbed trailer in the Houston area to haul my two motorcycles on!
Old Jun 8, 2005 | 08:25 PM
j-fox's Avatar
Here is a pic of my truck with racks. I have since painted the Ram insert blue to match the truck, and removed the top board. [IMG]jpg[/IMG]
Old Jun 8, 2005 | 11:02 PM
Here is a set of pics for my setup...
Close up of the post and fasteners...
Someone was asking about my setup now everyone can see it...
Old Jun 9, 2005 | 07:53 PM
JoeDiesel's Avatar
Where did you find the channel aluminum? Lowes / HD? Looks really nice! Definately a Cadillac Solution.
Old Jun 9, 2005 | 09:09 PM
Sorry to say it's a local boat builder that sold it to me... You might have to hunt around for metal shops to find something like it...I fits the stake pcket fairly good. Just a little bit of movement to allow a single person to handle a single panel. There are two other boards that go across the front and bolt on as well.
Basically I seen the same set up on the boat builders truck and had to have a set...
It called "The Metal Shop" in Riggins Idaho...
1985cucv
Nov 29, 2009 09:29 PM
plug ugly
Apr 11, 2008 11:47 AM
Jambbii
Oct 2, 2006 12:37 PM
CattleKev
0
Jan 26, 2006 07:57 AM
deere nut
Dec 9, 2003 08:35 AM
