anyone made their own double deep trans pan?
Old Nov 28, 2009 | 06:55 PM
1985cucv's Avatar
i was wondering if anyone has made their own double deep trans pan. i was thinking about taking 2 pans and cutting the bottom out of one and cutting the top flange off the other and welding them together. in turn it should give you 4-5 quarts extra fluid. or am i crazy for thinking about this? thanks
Old Nov 28, 2009 | 07:19 PM
rockcrawler304's Avatar
Doesn't sound crazy to me.
A buddy of mine extended his engine oil pan on a Jeep in a similar way. Extended the pick up the same way and no problems.
Old Nov 29, 2009 | 11:06 AM
1985cucv's Avatar
i think im gonna do it
Old Nov 29, 2009 | 11:42 AM
bansh-eman's Avatar
I don't see any issues with it. Nothing differant about it than buying a larger pan.
Old Nov 29, 2009 | 04:20 PM
matt69olds's Avatar
You need to drop the filter also, should be easy to make a spacer to drop it down
Old Nov 29, 2009 | 06:58 PM
zulusafari's Avatar
Why? Do the double deep pans from Mag-Hytec come with extended filter spacers? I don't think it is necessary, is it?
Old Nov 29, 2009 | 08:28 PM
1985cucv's Avatar
yeah they do have a spacer. i dont know what the issue is with it?
Old Nov 29, 2009 | 09:12 PM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
keep in mind that making it deeper means controlling the sloshing as well.
1- Pickup extended.
2- deep pan
3- baffles stratigically placed.
4- drain plug installed.
5- use the re-useable gaskets. they're great.
Old Nov 29, 2009 | 09:29 PM
bansh-eman's Avatar
I think the extended filter spacer is to make sure that you are actually picking up fluid and not air? As long as your filling to the dip stick mark I dont see why anything would need to be moved? It would be the same thing as a stock tranny pan only now you have nearly twice as much fluid in the pan.
The_Head
Sep 19, 2010 03:10 AM
EverydayDiesel
Nov 11, 2007 09:33 AM
KRB
Jan 28, 2007 04:54 AM
MrKen
Nov 23, 2006 03:19 PM
BigBlue
Sep 30, 2005 08:27 AM
