H2 wheels on 3500?
H2 wheels on 3500?
Is anyone here running Hummer H2 wheels on there 3500? I have seen alot of pics on 2500's, but no 1 tons. The reason I ask is that I am using Dodge dana 60 knucles and unit bearings for the outers on my 8 lug axle conversion, but I am not sure if the larger 3500 calipers will clear the inside of H2 wheels. Is there anyone that has a measurement of how far, if at all, the caliper sticks out past the wheel mounting surface on the 3500's? I know the 2500 system is about 0.200 under the wheel mounting surface. All of my info is based on 2500 axles being the 7500# gvwr listing and 3500 being the 8800# gvwr listing. But it may be single rear wheel 7500# and dual rear wheel models 8800#? Any thoughts?
The 7500# gvwr 2500 axle is a Dana 44 not a Dana 60, it was only used in V8 gas 2500s. The 8800# gvwr is the 2500 Dana 60. The 3500 will have a gvwr of 9500# or higher. The only difference between a 2500 and 3500 Dana 60 is the dually adapters on the 3500, the brake parts are the same.
Oh thats right, I forgot about the Dana 44 2500. I just got all tha parts for both GVWR's. All the 8800 stuff works fine in the front. I used the 7500 caliper with the 8800 pads and 99 Ford E250 c-clip Dana 60 rotors for my rear disc conversion. It was a good thing I grabed both sets, so I could mix and match for the rear. Thanks for the input.
There going under my 92 Jeep Comanche with a 93 4BTA/NV4500. The stock axles with chromo shafts and Detroit TruTrac differentials have worked good so far, but I think Im pushing the limits. http://s6.photobucket.com/albums/y23...PBash07009.flv
Tree DR
Dec 1, 2008 07:14 PM
dragginlx
15
Mar 9, 2007 11:32 AM
ptgarcia
Sep 12, 2006 06:04 PM
