guage options for 24V?
Old Mar 8, 2010 | 06:03 AM
royta's Avatar
On my '97 w/ Auto, I had a 3-guage pod with ISSPRO EV pyro on bottom, trans temp in middle, and boost on top. Now I have an '02 w/ 6-speed and am wondering what my options are. I definitely want to monitor EGT, fuel pressure, and boost.
I haven't spent much time driving the truck since I bought it on Saturday, but my initial feeling is that I'm not going to need power increases. That may change once I drain and replace all the fluids this weekend and actually start driving the truck. The Edge Juice with Attitude seems nice, but a little expensive for just engine monitoring. Plus, if I was going to make more power, I was leaning towards a Smarty. I'll admit I haven't done much research though.
I was in love with the ISSPRO EV back when I installed guages on my old truck in 2005, but now I see there is the ISSPRO EV2 and the Performax. How do the new ones rate?
I'll admit that I'm nervous to hack up the existing pillar in order to mount guages there. But I think that's the best place to quickly look at vital engine information.
Old Mar 8, 2010 | 12:39 PM
sheriffav8r's Avatar
Edge Juice w/ Attitude will give you all that and awesome performance....
Old Mar 8, 2010 | 03:16 PM
Tate's Avatar
Why would you hack up the pillar? Do you have the Infinity sound system? My aftermarket pillar just slides over and two of those plastic lock pins at the top. Lots of guys pull their OEM pillar and just put aftermarket one in by themselves.
Personally, I like analog gauges better than digital. You can just glance at them without actually having to read them. The juice does have some neat features though.
Old Mar 8, 2010 | 09:39 PM
rebal's Avatar
why hack it up? I have a pillar mount that has the infinity speaker hole I just put the speaker and gauges in the new gauge pod and removed the OEM one
Old Mar 8, 2010 | 09:47 PM
Dr. Evil's Avatar
I did that too but I dont like the way you can see inside the replacement pillar when the gauge lights are on (talkinga bout from the outside of the truck). Looks like crap. I find it works best installing the replacement pillar over the original.
Old Mar 8, 2010 | 10:01 PM
rebal's Avatar
? what ? whose pillar do you have? mine fit exactly like the OEM, i can see no light on mine it fits perfectly mine has Isspro ev in it
Old Mar 8, 2010 | 10:19 PM
royta's Avatar
On my '97, I used a AutoMeter Guage Works pillar. The Guage Works pillar would not have fit as well as the original does, so I opted to put the Guage Works on top. I had to use a hole saw and drill holes in the original pillar behind the guages in order to run the cables to the guages. There was no room for cabling between the two pillars, so the cabling had to run behind the original pillar.
king5335
26
Jan 17, 2010 07:57 PM
haddixj
Feb 5, 2009 03:09 PM
buddy26
16
Jan 14, 2009 07:29 PM
Blackbomb77
Aug 28, 2006 08:44 PM
EClancy
Oct 26, 2005 09:52 AM
