governor arm adjustment and Fuel Shutoff Solenoid
Old Nov 30, 2005 | 10:42 AM
Iron City's Avatar
I was reading a guide on tuning the P7100 pump here:
http://www.dodgedieseldatabase.com/t...up_a_p7100.htm
and in the article it is discussing the governor arm adjustment and it says "This should be done with the Fuel Shutoff Solenoid in the run ( or pulled up ) position." My question is how do you accomplish that? Is it done by turning the key into the run position? by manually doing it? Probably a dumb question, but I'm not sure what they mean.
Old Nov 30, 2005 | 11:05 AM
MasseyMan1089's Avatar
On the shut down solenoid, you can manually pull the lever up. Just stick your hand under the solenoid, and you will feel it.
Old Nov 30, 2005 | 11:07 AM
You have to manually pull it up because the switch does not pull it up until the engine is cranked over.
Old Nov 30, 2005 | 11:51 AM
infidel's Avatar
Key must be in the run position before you lift up on the solenoid otherwise it won't stay up.
Old Dec 1, 2005 | 09:03 AM
Iron City's Avatar
thanks guys, I'm glad I asked
dontoy
Sep 10, 2007 08:06 PM
dontoy
Sep 10, 2007 02:16 PM
Baja
Mar 26, 2007 09:37 AM
Lil Dog
Dec 8, 2006 01:41 PM
kawi600
Jan 8, 2006 05:12 PM
