Governer spring question
Old Oct 26, 2008 | 09:44 PM
William12Valve's Avatar
I was doing some tinkering on the truck and was wandering what the symptoms of the spring retainers being to tight or to loose.
Old Oct 26, 2008 | 10:30 PM
dv_shane's Avatar
too tight wont idle down under 1000-or so.
some had real loose springs from factory like 95 mine was only 3 clicks
Old Oct 28, 2008 | 12:05 AM
What are the symptoms of them being to loose?
Old Oct 29, 2008 | 06:12 PM
Does anyone know how the motor acts when the governor springs are set to loose?
Old Oct 30, 2008 | 10:22 AM
dzlfarmboy's Avatar
Usually will idle low, and not pull very far in the RPM band.
Old Oct 30, 2008 | 10:20 PM
The truck pulls all the way to 4k but the idle was low and the trottle was very touchy and almost hard to drive. If you moved the trottle like an inch it would continue to climb all the way to 4k. The driving characteristics just aren't the same as before and was wondering what the problem could be. Thanks for the help guys.
Old Oct 31, 2008 | 06:41 AM
dzlfarmboy's Avatar
Thats the way 4k's are, if you want it a lil less touchy loosen the springs some.
Old Oct 31, 2008 | 09:18 PM
I will give that a try thanks a bunch
Old Nov 1, 2008 | 04:28 PM
rootremblay's Avatar
I installed my 4k and it drives the same as stock except less throttle required for 2500 rpms. No surging, sensitivity issues, nothin. And it will run 4k if i hold the auto in 2nd, thats hows i tested her out. Haven't seen that high an RPM since. I noticed if the springs are adjusted wrong to much idle adjustment will make the rpm's hang up, I guess do to the fact that it takes a quarter inch of throttle to cruise 50 mph. I had to tighten mine down a little past what the factory GSK was. I got it close with a digital caliper and went from there by runnin the truck every set of clicks.
TxDiesel007
Aug 24, 2006 10:56 AM
TxDiesel007
Aug 21, 2006 10:43 PM
John H
May 28, 2004 11:47 AM
turbospl311
Nov 29, 2002 08:58 PM
