got a turbooooooo question
Old Oct 29, 2003 | 12:49 PM
barracuda's Avatar
K...here's what i got..i was going to buy a boost elbow for my truck and i remembered reading something about a "hardlined wastegate" or something like that...looking at my sig.(automatic trans) ...is my truck hardlined??their appears to be a braided steel line coming from it if that's any help...if so, do i use a turnbuckle? and what do i do exactly to install if i need this...i need more boost, have fueling box and im guessing more boost would help w/ egt's and also make me smile a tad more at the same time ;D
Old Oct 29, 2003 | 01:30 PM
StakeMan's Avatar
Re:got a turbooooooo question
2001 is when the HY35 with the hardline wastegate tube was introduced. The braided line is the oil line.
Old Oct 29, 2003 | 01:32 PM
hellotbone's Avatar
If you search the forum for turnbuckle you should find a pic I think there is one on the edge site as well.
As for the SS line thats your oil feed line. Leave that baby alone!
Old Oct 29, 2003 | 01:33 PM
GatorRam's Avatar
Cuda,
I have a 99' which is basically the same setup as yours. The answer about a the hard line is no, you don't have one. The braided line that you see is your oil supply line. If you look closer on the compressor side of the turbo you will see a little brass elbow that is connected to a piece of black hose the goes to the wastegate actuator. This elbow is what gets replaced on our model years. I have had an Edge EZ and currently have a comp and they both came with the new elbow and would have figured that yours would have to but I guess not. Hope this helps.
Adam
Old Oct 29, 2003 | 01:36 PM
banshee's Avatar
You'll be good to go with the boost elbow. The hardlined wastegates are only on the HY-35/9s that came on '01 and '02 autos. The stainless braided line coming out the top is your oil feed line... don't mess with that. The boost elbow is a brass 90 degree elbow that replaces the elbow in your turbo. It's located right off the compressor housing and will have a rubber hose running to the wastegate actuator.
John
Old Oct 29, 2003 | 02:18 PM
barracuda's Avatar
aaaahh haaah!! thank you all very much, guess i need to brush up on my turbo skills..( spent alot of time on my fuel system skills )...wont be touching any braided lines anytime soon!! hay GATORMAN...looks like u got an extra elbow laying around...PM me if u do...
Old Oct 29, 2003 | 07:01 PM
Rattletrap1's Avatar
Your box must have a boost fooler or going above 20 psi will throw a code and a check engine light.
Dale M
Mar 5, 2011 03:40 PM
bhoff1175
Jun 7, 2006 10:19 PM
Begle1
Jul 13, 2005 04:13 PM
joel
May 23, 2003 07:02 AM
crankbait
Feb 14, 2003 04:31 PM
