Got a question
Old Oct 5, 2004 | 02:15 PM
winkle's Avatar
Got a question
Got a question,
On my AFC housing on the opposite end of the diaphragm there’s slotted bracket that’s secured with a 10mm bolt that attaches to an eccentric pin that moves the do-hikie that rides next to the fuel plate up & down. What is this adjustment for?
Old Oct 5, 2004 | 03:14 PM
SHARPMACHINE's Avatar
I think that you are talking about the fuel shut-off valve....hope that helps.
Old Oct 5, 2004 | 04:20 PM
winkle's Avatar
No it's not the fuel shut off valve.
The arm that the AFC diaphragm accuates when under boost is the arm that this eccentric pin move up & down when you rotate it.
Old Oct 5, 2004 | 11:34 PM
Jason Starnes's Avatar
the "do-hikie" has a taper on it I think the adjustment you speek of is just a fine'r adjustment for the afc
just to tune smoke a slight ammount
Dale M
Mar 5, 2011 03:40 PM
bhoff1175
Jun 7, 2006 10:19 PM
Begle1
Jul 13, 2005 04:13 PM
joel
May 23, 2003 07:02 AM
crankbait
Feb 14, 2003 04:31 PM
