Good power setup
Old Feb 6, 2004 | 05:24 PM
Lil Red's Avatar
Good power setup
Right now I have 300 injectors and an AFE intake. Bought the pump off the internet bein said also that it had a 15% hp upgrade. What is a good setup to have with the 300 injectors far as cam plate and DV's go. Eventually I want to go with 370s so I would like the cam plate and DV's to work with them also. Thanks.
Old Feb 6, 2004 | 10:22 PM
mcevins's Avatar
Lil Red,
You could go with a #4 or #5 plate from TST. I think the #5 is all that is recommended on the 160 pump. That's with stock injectors. Do you have an auto or 5 speed? If you go much further than the 300 injectors I think you would need a new clutch or auto tranny upgrades.
If you have the clutch or tranny upgraded go with the #5 or #4 plate. The high flow delivery valves will help also. My 160 pump wouldn't supply enough fuel for the 370's and would miss at 2,800 rpm's. I had the 3000 governer spring kit also. Most vendors will turn you in the right direction on upgrades on the 12v Cummins.
Don't forget guages!!!!
Good Luck!
Meacham EvinsTST Chart for Torque Plates
sallyman1
Apr 1, 2011 06:46 PM
Rancher99
Mar 29, 2011 02:59 PM
Flatbed24v
Jul 14, 2009 09:05 PM
ryanihf250
Jan 17, 2008 02:58 PM
12valvesmoker
Oct 17, 2004 10:09 PM
