GOOD COMP~BAD COMP?
Old Feb 8, 2003 | 03:45 PM
danlit's Avatar
GOOD COMP~BAD COMP?
Today coming home from work my truck was feeling a little funny.( SLOW). I noticed the lights on my comp were going on &amp; off in different patterns and the 1st fuel light won`t come on at all.<br>I checked all connections, still the same. Has anyone had this happen?<br> Danny
Old Feb 8, 2003 | 03:49 PM
Cumminsdieselboy's Avatar
Muted User
Re:GOOD COMP~BAD COMP?
Yeah you are probably in the sub menu. to go back to main menu, first turn it up to 5 if you want and turn it off. then turn it back on and it will be fixxed then set desired level. If your like me 5X5.
Old Feb 8, 2003 | 04:04 PM
danlit's Avatar
No Im not in the sub level, If you read it says FUEL level. there is no 1st level light and if I go up to L5 they go on&amp;off and Dim (just stay dim not flicker as in sub level)<br> Danny
Old Feb 8, 2003 | 04:31 PM
TPilaske's Avatar
Call Edge or post a message on their forum, I think someone just posted a similar issue with there's. Might have to send it back to Edge for testing... [undecided]<br><br>Tony
Old Feb 9, 2003 | 02:09 AM
Big Bob's Avatar
I had one of my comps do the exact same thing. Call Edge, they will replace it. ;D
Old Feb 11, 2003 | 08:16 PM
danlit's Avatar
Well it turned out to be the Box. I have to say Edge Products are great to deal with. I called monday morning talked to Aaron and had a replacement box in my hands the NEXT day.<br>Small overnight charge well worth it. Can`t believe the difference the other box must have been Bad from the start and continued to get worse.<br> Danny
Old Feb 12, 2003 | 02:56 AM
katoiler's Avatar
Danny,did you have any other problems with it? mine seems to run good sometimes and other times it don't.had it lock up twice and had to turn the truck off and it reset.<br><br> Mike
Old Feb 12, 2003 | 10:24 AM
BigBlue's Avatar
Occasionally, mine will light up every other light and not do anything till I unplug it. Sometimes it won't come on at all. It also surges after running it on 3x3. I need to send it back but have the money to. Considering the thing is like a year old or something, I don't think there is a warranty on it any more.
Old Feb 12, 2003 | 12:00 PM
99 cummins's Avatar
I have had my comp installed for a few months now, but just here recently when I change the settings on the fly the truck seems to miss a beat at each level change. It's not bad by any means, but didn't do it at first. Just wondering if anyone else has this happen so that I know if it's normal.
Old Feb 12, 2003 | 02:20 PM
Ryan's Avatar
[quote author=99 cummins link=board=7;threadid=10707;start=0#103781 date=1045072807]<br> I have had my comp installed for a few months now, but just here recently when I change the settings on the fly the truck seems to miss a beat at each level change. It's not bad by any means, but didn't do it at first. Just wondering if anyone else has this happen so that I know if it's normal. <br>[/quote]<br><br>There is any easy solution to that, set it on 5x5 and leave it there. ;D I try to avoid changing the settings unless I am setting at an idle.
Old Feb 12, 2003 | 07:42 PM
danlit's Avatar
Mike, Mine was only 2 weeks old. At first it seemed fine, except for level 4 &amp; 5 above 2200 rpms it felt like it was getting to much fuel and had a hard time reving past 2500 rpms. It steadily got worse, last day it totally defueled @ 1400<br>if I shut the box off it would not even make enough power to make 5psi of boost(which made no sense, I was thinkin lift pump. but still had 16 showing on gauge) After new box its day &amp; night difference.Lights were working all funny also. I checked all connections. I did move the + wire to the blue wire coming down the steering column, buddy told me its much better power than tapping the panel.<br>I knew something was wrong when I almost couldn`t make it home.<br> Danny<br> Blue Try turning the sub level up .3 is as low or lower delivery level than stock, You`ll get a pop in the rpm when you let off the pedal.
Old Feb 13, 2003 | 10:44 AM
BigBlue's Avatar
If I run mine on 3x3, then put it back down to 1x5 and am crusing, the truck will surge BAD. If I put it on level 2x3, the surge disappears.
Old Feb 13, 2003 | 10:53 AM
hellotbone's Avatar
Send it back mine does nothing to what you guys are saying. No surging no lights flashing no anything just works all the time! I can run any level and the box works perfect. No probs what so ever.
65fury
25
Apr 6, 2007 08:16 AM
getblown5.9
13
Oct 4, 2006 04:59 PM
Buckshotram
Jan 9, 2006 09:27 AM
C Pierce
Mar 21, 2005 08:41 AM
hellotbone
18
May 16, 2003 04:40 PM
