GDS and HTT compressor upgrade ?s
Old Jun 15, 2009 | 03:33 PM
STACKED's Avatar
Both say that internal mods are needed but what does that consist of?
Since the turbo needs to be modified, could i do it my self or is it better for me to send it off and spend the 85 for them to do it?
What is the difference in the performance of the GDS 8 blade 60mm wheel and the 6 blade 60mm wheel?
Old Jun 15, 2009 | 04:51 PM
scottsjeeprolet's Avatar
Good luck with that. I called HTT and they basically blew me off.
I just need to get my compressor cover machined. I already have the 35/40 center section.
Old Jun 16, 2009 | 12:56 AM
Big Blue24's Avatar
Your stock HX35 compressor wheel has a 78mm major diameter. The HX40 upgrade 60mm compressors have an 84ish mm major diameter so the center section of the turbo need to be milled a little so the larger diameter wheel can fit. No need to machine the compressor cover since the upgrade comes with a new larger cover that is matched to the 60mm wheel.
The difference between 8 blade and 6 blade 60mm wheels is slight difference in airflow and larger difference in sound. The 6 blade wheels SCREAM but they do flow a bit more air.
Old Jun 16, 2009 | 06:09 AM
I have the 6 blade 60mm x 86mm compressor.
I've been contacted by someone at HTT and hopefully can get this done.
Old Jun 16, 2009 | 10:30 AM
STACKED's Avatar
Could it be machined by my local machine shop pretty easily?
ClassA4x4
Dec 20, 2014 10:52 AM
12V_shooter25
Jan 11, 2013 04:07 PM
Richie O
Mar 20, 2009 10:07 PM
vr1967
Apr 14, 2008 02:18 AM
CaptainChrysler
Dec 29, 2007 10:04 AM
