gauges please help
gauges please help
Well since the trwins are on their way i need new gauges. I am getting a fuel prerssure, pyro, and 2 boost gauges. I am going with stewart warner since i can get their new lighting system free and the fact they are good gauges. My questions are: How do i tap for a fuel pressure gauge? If anybody can tell me the exact hardware i need i would be grateful (for an electronic gauge). Also where would i put the drive pressure boost gauge on the setup i am getting? And finally where in thew hell do i mount the fourth gauge. I dont like the steering column mount because i need to only mount 1 gauge. And i dont want it there. anybody have any pict of where they mounted their gauges.
thanks Rick
thanks Rick
Quad guage A pillar:
http://www.smokindiesel.com/gauges/pillars.html
Banjo bolt or a T fitting for the fuel guage. Most guys just run this to a needle valve thats left barely open then to the guage instead of using the isolator
http://www.dieselmanor.com/dm_products/dm-products.asp
Parts needed for the fp install are t-fitting/ tapped banjo bolt, needle valve, and two peices of fuel line. It should all be 1/8 npt fittings.
thanks for the reply but the 4 gauge pillar is for ford only. I am using the indash mount from genos garage. and as for the fuel pressure i am getting an electrtinic gauge instead of a manual. I hear that i can use a port on the top of the fuel canister but i dont see it. Any ideas?
Kman9090
29
Dec 6, 2007 06:43 PM
coontz0473
17
Sep 22, 2006 03:52 PM
AggiePhil
Jan 30, 2005 01:15 PM
